[B]What clutches are you using?[/B]
Old May 23, 2006 | 05:56 PM
twincannon26's Avatar
Junkyard Dog
my car has mild upgrades and bigger turbines, and smokes the new(er) oem clutch horribly when shifting into 2nd at high rpms. therefore, a new, stronger clutch is in order. im wondering what clutch kits you guys are using, my car is my current daily driver and i want it to remain streetable, but still be able to stomp the occasional street racer at redlights. thanks.
Old May 23, 2006 | 06:05 PM
takahashiRyosukeFC3S's Avatar
1 miracle from sainthood
can't go wrong with ACT http://www.rx7store.net/product_p/z65-xt00.htm
hope that helps,
TR
Old May 23, 2006 | 06:10 PM
rotary downshift's Avatar
+1 this saturday if all goes well with the seller im picking up act hdpp and oem dish .. act clamins up to a max of 80% tq increase in holding capacity with that set up .. so it might be a thought
Old May 23, 2006 | 07:23 PM
spot_skater's Avatar
The Cause of Death
I've got the ACT Street/Strip clutch disc and HD pressure plate. It clamps a bit harder than stock, and bites hard, and is very streetable. Pedal is slightly firmer as well...but not by much. SS braided clutch line should help with that, though.
Old May 23, 2006 | 07:50 PM
Dom_C's Avatar
act extreme pressure plate. . broke my clutch fork pivot. But is a great clutch. I would recomend it. The clutch fork pivoit retainer also broke, if that broke first that may have been the cause of the pivot failing. It is quit the clutch, has never even thought of slipping on me.
Old May 23, 2006 | 08:38 PM
Juiceh's Avatar
Saiga-12 Power!
I've got the ACT Street/Strip clutch disc and HD pressure plate as well. Its a pretty good setup. I've recently heard alot about ACT clutch failures and broken forks. Though I haven't had any problems with my ACT setup I am going with an Exedy Hyper Twin for my new turbo setup.
Old May 23, 2006 | 08:45 PM
Smoken''s Avatar
Act extreme pressure plate with 6 puck disk. I haven't had any problems with mine yet. From what i have seen however, the clutch forks like to break because of the pressure plate being so stiff.
Old May 23, 2006 | 08:49 PM
88rxn/a's Avatar
tom port.. AKA streetport
ill be different!! lol
centerforce dual friction
feels like stock..handles up to 300HP
Old May 23, 2006 | 08:50 PM
vhold's Avatar
Clutchmasters stage 3. I don't know if they make them for the FC anymore, no listing on their site. I have no complaints.
Old May 23, 2006 | 08:51 PM
gishgish's Avatar
I have a twin plate in the RX-7, so it is not very streetable, but all of my daily drivers over the years have had exedy stage 1 and 2's. Very good. My ZC CRX has a stage 1 and it drives like a stockie, until I let it out too fast off the line, and it will remind me it is not, in fact stock.
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
