Am i leaning out?
Old May 22, 2006 | 07:56 PM
88turbotime's Avatar
I'd hit it.
Am i leaning out?
Alright guys i need some help. The car is an 88 TII, with K&N intake, racing beat turbo back, street port, removed emissions, koyo radiator, and walbro 255. And i do have the fuel cut defensor. oh yeah and the wastegate is ported.
When i go wide open the motor kind of "hesitates" at 6500 rpm. It feels like you just let off the gas. I am afraid that the car is leaning out, or that i am hitting fuel cut even though i do have the fcd. Boost reaches about 6-8 psi in first and about 8 in 2nd gear. Kevin landers built my motor and installed my stuff, and he did say that he thinks by looking at the plugs that the motor is running a little lean, or at least "very clean" as he says. Im not doubting that he knows his stuff, but other people say that there is no way i should be running lean with so few mods and the walbro 255, especially since the fuel pump is going full blast all the time. So im just wondering if this sounds like im leaning out, or hitting fuel cut, or something else. Thanks.
Old May 22, 2006 | 08:26 PM
I'd hit it.
someone just told me that I should start running all trailing spark plugs. Instead of using 7s and 9s, use all 9s. Is this a good idea? i have never heard of that.
Old May 22, 2006 | 08:51 PM
13b4me's Avatar
Are you running stock injectors? If so there's your lean condition... You're maxing out the duty cycle of the stockers...
Old May 22, 2006 | 09:31 PM
I'd hit it.
yes i am running stock injectors. so for my mods what do you suggest? maybe some 720 secondaries? keep in mind i have no real way of tuning this car, no wideband or anything. so i dont want to run super rich, but not lean either obviously
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
WyomingTII
Sep 28, 2015 10:32 AM
