Oil level wiring ?
Old May 22, 2006 | 06:12 PM
mwpayne's Avatar
Admitted 'rexaholic'
Oil level wiring ?
After a cooler hose failure, I'm getting more paranoid about watching my oil pressure
and levels. I have a 88 vert with a rebuilt TII engine, but the sender wires come up
from the oil pan with nowhere to go. Any idea of just what plug/connector I'm looking for
to make the level sensor work? A pic of a working one would be GREAT!
Heck, the connector may not even exist anymore, I may have to tap directly into the ecu..
Old May 23, 2006 | 02:55 AM
NZConvertible's Avatar
I'm a boost creep...
The warning lights and buzzers have nothing to do with the ECU...
The oil level sender has a red/white wire that comes out of the engine harness (starter/battery/alternator) around the same place as the wires for the oil pressure sensor (yellow/red wire) and oil temp switch (black/red wire).
Old May 23, 2006 | 05:51 AM
mwpayne's Avatar
Thanks NZ, I'll look again and see if I can find it.
The1Sun
Mar 18, 2018 11:08 PM
Snoopy FD
Dec 8, 2015 01:45 PM
rocker1337
16
Sep 6, 2015 11:28 PM
BLK 93
Aug 19, 2015 03:47 AM
