12a wiring reduction question
Old May 22, 2006 | 03:30 PM
Clearkut's Avatar
What could possibly go wr
Its for an 85 12a, Its got a 48IDA on a half bridge( I know its not ideal but it is what I have)I'm looking to simplify the little wire harness coming from the passenger side of the firewall, the one that goes to the stock carb/lower intake, and ratnest, and so on, since I have the weber, I have no need for most of these connectors as far as I can see, but if anyone knows other wise I would like to know which ones can go and which ones must stay
Old May 22, 2006 | 03:58 PM
Siraniko's Avatar
RX for fun
Im runnig the same thing. The 4 wires you will need are: alternator (2 wires), water temp and oil pressure wires. Label those 4 wires, then unplug the entire harness (2) from the passenger side. Now, for the fun part, instead of just cutting the wires, push the pins out. this will make it a clean install. Then you cut trim them to your desired lenghts but be sure to solder the wires.
Old May 23, 2006 | 12:22 PM
Clearkut's Avatar
Thats what I wanted to hear and I thank you kindly for your time.
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
