After market H20 Gauge
Old May 20, 2006 | 06:08 PM
Kill No Cone's Avatar
Ok, so what do you do to add an adtermarket water temp gauge? The mazda has a little pipe threaded sensor, but no room for the large sensor that comes with the gauge.
So, what have you done?
Thanks ~ JEB
Old May 20, 2006 | 06:24 PM
z-beater's Avatar
REW'd FB
I use my microtech
In all seriousness though. I looked into this a while ago and found a how to thread that was helpful. I am not sure if it will work for your specific application for a couple reasons.
1. Not sure what sensor you are using
2. This is for an install on a REW. And since that is what I have that is all I am concerned with.
https://www.rx7club.com/showthread.p...e+installation
Hope this helps.
Z
Old May 20, 2006 | 09:05 PM
Hyper4mance2k's Avatar
The Shadetree Project
I took a 2" piece of copper tube form homo creepo and drilled a hole in it just too small for the fiting then I put a bunch of JB weld on it and turned it in. cut my top radiator hose in half then put it in between.
Old May 20, 2006 | 09:11 PM
81gsl12a's Avatar
blown up motors
i took the senser out that is below the thermostat..and filed the brass fitting down a little and forced it in.........no leaks (if you do this be careful not to brake it of in the housing brass is very soft) or you can do like i did and go everywhere for like 2 weeks looking for the pice that no1 has to get it to fit the right way
cheers PaTricK
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
