fuel leak?
Old May 18, 2006 | 05:36 PM
lemonade's Avatar
You can choose this?
fuel leak?
fuel is leaking out of the carb, the air filter specifically when the fuel pump is on. does this mean the floats arent functioning properly? if so, how do i firx this? its a 48mm side draft dellorto
Old May 18, 2006 | 06:00 PM
kgray's Avatar
GOT WANKEL?
What fuel pressure are you running? Do you have a FPR?
Old May 19, 2006 | 04:50 AM
Kim's Avatar
Kim
OBEY YOUR MAZDA
Must resist obvious suggestion.
Old May 19, 2006 | 08:03 AM
lemonade's Avatar
fuel pressure regular is set at 6psi, as it has been for as long as i can remember. this wasnt a problem last time a ran it. it's been sitting for a while though.
Old May 19, 2006 | 08:07 AM
gsl-se addict's Avatar
Super Moderator
I am not much of a carb guy, but I think this happens if:
- fuel pressure too high
- floats stuck/misadjusted
- needle seat bad
Hopefully someone can tell you what exactly to try. Good luck.
Kent
Old May 19, 2006 | 11:49 AM
gmanuser's Avatar
wheres my calculus book?
it sounds like something might have come loose i know this sounds stupid and i am not exatly sure on how your carb is set up but in general on carberaturos thier is at least on ebolt holding on the fuel line mounts where you put on the fuel line make sure that those are tight and that they are all in (wich i hope they are because you didnt say that you really did anything to it to make it do this) also check and make sure that your fuel line mount is not clogged or backed up becaus e of a obstructing obstical.
Old May 19, 2006 | 05:38 PM
lemonade's Avatar
all of the fuel line seems to be fine the whole way, the fuel is coming out of the carburator. i guess it couldnt hurt to take it apart and put it back together
Old May 19, 2006 | 06:24 PM
trochoid's Avatar
Old Fart Young at Heart
Either the pressure is too high, the floats are stuck, or the needle seat is stuck. I know on my Mikuni, when I was first setting fuel pressure with a new pump and fpr, at 12 psi, fuel ran out of the velocity stacks.
I'd say it's time to take it apart. clean and check the float setting, (which should not change on it's own, unless the the floats have sprung a leak and filled with fuel), and check the needle and seat. If the have them, not that familiar with the Dells.
Microtech
30
Apr 23, 2016 06:37 PM
Captain_Panic
Alternative Fuels
Sep 16, 2015 02:06 PM
86glxNA
Aug 22, 2015 08:54 PM
