When stick in gear but no clutch, engine cold the engine stops. Idles really low.?
Old May 16, 2006 | 03:43 PM
santacrs's Avatar
Gotta love cali weather!
For some reason when the temperature gauge is set to Cold and the gear shifter is anything but neutral the idle with drop rapidly until the its so low the engine stops. This started when is got warm and after I took it PFS for tuning and air fuel adjectment to remove backfiring. Backfiring stoped but this started.
I've got a remapped cpu , Apexi Air/Fuel Controller and
GReddy Boost Controller Profec Type S?
Anyone have any ideas?
Thanks
Sebastian
Old May 16, 2006 | 08:04 PM
cewrx7r1's Avatar
Eye In The Sky
Sebastian
You have the answer in your facts.
Old May 16, 2006 | 09:50 PM
extreme_rotary's Avatar
Are we talking about a manual transmission that stalls the motor when you put it in gear, but keep the clutch pedal depressed?
Old May 16, 2006 | 10:09 PM
tcb100's Avatar
DinoDude
Clutch switch.
Old May 17, 2006 | 09:49 AM
santacrs's Avatar
Extreme_rotaty thats exactly what it does. Its been doing this since I brought it to PFS. The messed with the air fuel setting I believe to remove the backfiring. However this started happening. The wierd part is if I keep the stick in neutral it idles fine when cold but as soon as I move the stick to any gear and keep the clutch depressed, the rpms slowly drop to 0 in a matter of seconds.
Old May 17, 2006 | 09:51 AM
tcb100's Avatar
DinoDude
Clutch switch.
Under 10 bucks and under 10 minutes to install.
Old May 17, 2006 | 11:20 AM
White94RX's Avatar
BMW Tech
I second that motion. Mine never stalled, but with the clutch depressed, it idled rough when I put it in gear. I fixed mine with the spring out of a ballpoint pen because the spring had broken. It's the switch at the top of the clutch pedal. Can't miss it.
Kyo
Apr 13, 2019 09:24 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
ncds_fc
Aug 15, 2015 10:06 AM
