fuel gauge problems?
Old May 16, 2006 | 08:53 AM
_raven2510_'s Avatar
Post Whore
my fuel gauge dosent work? whats the problem...
Old May 16, 2006 | 08:57 AM
mazdaverx713b's Avatar
Have RX-7, will restore
ummm, check the connection at your sender first. its located in the left wheel well. jack the left rear up, take the tire off pull back the plastic and make sure there are no broken wires or the connection isnt oxidized or corroded. if thats fine, make sure the connector in the back of the cluster for the fuel gauge is hooked up. if thats fine, drop the tank, pull the sender and measure its resistance while moving the arm. if resistance is out of spec, replace the sender
Old May 16, 2006 | 11:20 AM
Post Whore
thanks ill try that and get back to you....
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
