Boost Gauge reads wierd
So i have a boost gauge that reads 10-12psi when idle and 8-10 vac when max boostering and like 20-30 psi when i let off the gas. i don't know if it's just broken or is hooked up wrong or what. any idles.
and the controller is set to 8psi i believe
My guess is that you are reading the gauge wrong and don't know what to expect. This is what you are probably seeing, and is about what I would expect to see:
1. at idle, it reads 10-12 in Hg of vacuum (not psi of boost)
2. at max boost, it reads 8-10 psi of boost
3. when you let off, it reads 20-30 in Hg of vacuum
-Max
-Max
streetlegal?
Mar 17, 2022 02:46 PM
