Microtech Won't start unless laptop is connected
Old May 9, 2006 | 08:13 PM
mazdarick's Avatar
LS1 Here I come.
I've got this strange problem where I go for a ride, stop at a store, or gas station and leave the car off for a little bit. When I get back in, the car won't start unless my laptop is connected to the ecu. It's always connected physically, but If I don't press F1 to connect with the software, I would just crank all day. As soon as I press F1 and turn the key, she starts right up. I've verified this even when cold and have been proving my theory for over a week now. Do you think that if the Laptop adapter is attached to the ECU, that the software must be also connected. I haven't tried removing the Laptop adapter and tried to start with nothing connected. At first I thought I was going crazy, but have showed several friends and they were amazed that my car wouldn't start unless I was connected. Once started, I can close the software with no problems. Any ideas????? I'm stumped.
Old May 10, 2006 | 01:50 PM
BOOSTED Vert
check to see if your tps is reading correctly... That seems weird to me, but If its not the tps, then it must be ecu malfunction... Try it out to see if the yellow light is solid with the key in the ON possition
Old May 10, 2006 | 03:24 PM
mazdarick's Avatar
LS1 Here I come.
Yeah, I've already checked all that. I'll try to unplug the cable all together tonight and see what results I get. The problem is that I have an in dash computer system in the car that has the cables always hooked up. I'll post my findings as soon as I find out more.
Old May 10, 2006 | 07:00 PM
mazdarick's Avatar
LS1 Here I come.
OK, I unplugged the serial cable from the ECU. Turned the key and cranked 15secs. Waited 10.. Tried again, and again, and again. Then plugged in serial cable and pressed F1 to connect. Turned the key and within 3 secs, she fired right up.
I'm completely stumped.
Old May 10, 2006 | 07:09 PM
73828793's Avatar
went RX crazy............
read the manual there is an option where the ecu has to be connected for the car to start. once this feature is disabled you will be able to start the car without the laptop being connected...
Old May 10, 2006 | 07:41 PM
mazdarick's Avatar
LS1 Here I come.
Really??? I've read it several times. Just looked again, and couldn't find it. Can you tell me what the feature is called?
Old May 11, 2006 | 08:17 PM
73828793's Avatar
i will find what it is called and tell you tomorrow when i go to the shop and hook up the laptop to the FD. i had that feature on once and it was annoying so i disabled it.
Old May 15, 2006 | 09:00 AM
73828793's Avatar
sorry for the delay but here is your answer.... screen #32 option #2 E.C.U, this option should be "Enabled" cause if it is set to "Lock On" the vehicle will only start with the microtech software connected to the EMS by way of a laptop. so switch that option to enabled and you should be good to go.
Old May 19, 2006 | 07:41 PM
mazdarick's Avatar
LS1 Here I come.
Dude,
I owe you a ton. I never noticed that this was changed. Thanks again and again and again. I even emailed Microtech and Tim P. didn't even offer this suggestion. I don't know why. Just went out and changed this, and she started right up. THANK YOU!!!!!
Old May 19, 2006 | 07:44 PM
73828793's Avatar
Dude,
No problem, this is exactly what the forum is for...
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Im faster
Aug 19, 2015 02:57 PM
