MasterPower's new GT turbine range
Old May 8, 2006 | 12:54 AM
bobybeach's Avatar
Masterpower now have a new range of turbine design, I like to call it the gt range however Masterpower call them mpbt turbines.
They are still found in the common t4 range o p and q as well as many other trims in-between these, so basically will still fit all the common Garrett t4 housings.
here is a pic of the older p trim (left) vs the gt spec p trim (right) offered by Masterpower.
they are taller in height but have the same major and exduser dimension as the older range. With one less blade and totally new casting shape I am anxious to see how these compare with the older Garrett version.
I am hoping the new blade design with lighter construction will result in a faster spooling higher flowing t4 wheel than the previous masterpower garrett versions.
Attached Thumbnails MasterPower's new GT turbine range-000_0724lowres.jpg   MasterPower's new GT turbine range-000_0726lowres.jpg
Old May 10, 2006 | 01:58 AM
Steve-O-NZ's Avatar
Re: Mpbt
Was about to start a thred for the same thing, lol
Would also be keen on seeing how they compare to typical garret T series wheels. Sounds Promicing. Anyone else used em, seen one or heard anythin about them?
Old May 10, 2006 | 02:21 AM
87GTR's Avatar
Im looking for a turbo now, can you get a devided housing with a vband? I was looking at Master Powers site but they dont say anything about a new line of turbos
Old May 10, 2006 | 06:34 AM
bobybeach's Avatar
haha yea i now, its even hard for me to get new product info from them. i have to keep inquiring to kep on top of it. But they are working on a new website at the moment.
yes divided housing with v band is no problem. .84 or 1.00. both are devided and available with v band.
Old May 10, 2006 | 10:13 AM
BoostedRex's Avatar
NorCal 7's Co-founder
Oliver, so will this new line compare with the Garret GT series or no? I'm not quite sure I understand the new line. But do give us some more info as you get it from MP.
Zach
Old May 10, 2006 | 10:33 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
are they going to make turbine flow maps available?
Old May 10, 2006 | 10:36 AM
2a+RoN's Avatar
^^that would be awesome if they did..
Old May 10, 2006 | 11:29 AM
SPOautos's Avatar
Hey, where did my $$$ go?
You sure thats not just a knock off of a standard Garrett GT series wheel?
Old May 10, 2006 | 11:36 AM
who cares? if there's no map, how do you know how to select a turbine?
Old May 10, 2006 | 11:59 AM
Turblown's Avatar
Turn up the boost
Any luck on finding those old school garrett maps?
it would be nice to compare vs master power
Old May 10, 2006 | 12:17 PM
BDC's Avatar
BDC
BDC Motorsports
The old fashioned way: Experience.
B
Old May 10, 2006 | 12:48 PM
crispeed's Avatar
'Tuna'
It's not
It's actually a knock off a turbine wheel design that's about 5yrs old allready.
It is still an upgarde from the original Garrett design though.
The GT turbine wheels are complety different design than the ones above. The only thing common to both wheels is that they are both 10 blade designs but flow wise the GT wheel is in a league of it's own
Old May 10, 2006 | 01:04 PM
BoostedRex's Avatar
Thanx for the clarification Crispeed. I was curious as to what the true difference was.
Old May 10, 2006 | 01:35 PM
Turblown's Avatar
Turn up the boost
Is the casting quality on par with Garrett?
Old May 10, 2006 | 05:06 PM
bobybeach's Avatar
Zach
no they are different to the garrett gt range.
will keep you guys posted
Old May 10, 2006 | 05:08 PM
bobybeach's Avatar
not sure, i do know there compressor flow maps were suposed to be available at the begining of this year.
so will need to check with the progress on that.
Old May 10, 2006 | 05:24 PM
bobybeach's Avatar
Originally Posted by crispeed
It's not
ahhh.... 5 year old technology Knock off?........ I think you need to be clear if thats an opinion. Masterpower is not a small Company, they do have an R&D team to develop new and improved technolgy.
but yes i dont believe they are the same as garrett gt.
Old May 10, 2006 | 05:34 PM
B
you could go through 10 turbos and get it close enough by guessing....OR, you can look at a map, compare it to what you know, and get it right the first time.
Old May 12, 2006 | 06:13 AM
87GTR's Avatar
Yup!!!
Old May 12, 2006 | 11:35 AM
BoostedRex's Avatar
Oliver, could you shoot me a PM with your turbo pricing please? There have been some people around here asking me about MP turbo's and I wanted to go through you first since I know I can trust you to take care of people. Thanks in advance.
Cheers,
Zach
Old May 13, 2006 | 06:07 AM
bobybeach's Avatar
Cheers,
Zach
cheers Zach. pm sent
Old May 16, 2006 | 12:44 PM
master power got ball bearings yet?
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Rotate86
May 18, 2018 02:44 PM
BLUE TII
Sep 26, 2015 10:12 PM
RedBaronII
Sep 20, 2015 11:29 AM
