turbo builds boost really really slow
Old May 6, 2006 | 03:59 PM
snowball's Avatar
I live in the lounge...
its been an issue for awhile, but being my first turbo car I didnt know.
the turbo gets to 0 boost at about 2,500rpm
but then it slowly spools over the whole RPM band from their taking untell ~5000rpm to hit 12psi.
Im thinking the wastegate might be the problem, a friend has a HKS standard i may try out. does anyone else have any ideas?
i think i should be hiting full spool by at least 3500 with the t04B 1.15 hot side.
Old May 6, 2006 | 07:25 PM
Zero R's Avatar
Just in time to die
Check for exhaust leaks before the turbine. ie gaskets, wastegate etc. Check for leaks on the induction side as well. A 1.15 is not exactly a small housing either so that will contribute some.
Old May 6, 2006 | 08:17 PM
snowball's Avatar
yah i know its not a small hot side, but the cold is pretty small. So it seems like it should have a decent spool.
Old May 6, 2006 | 11:49 PM
fstrnyou's Avatar
check your wastegate and gaskets first.
Old May 7, 2006 | 11:13 AM
snowball's Avatar
does anyone have some tips on how to check the parts IE wastegate. Any help would be welcome before i decide to tear it all down and order new gaskets for everything.
Old May 7, 2006 | 11:18 AM
BDC's Avatar
BDC
BDC Motorsports
I agree with the others. This problem is indicative of a manifold air leak or an exhaust gas leak prior to the turbo.
B
Old May 10, 2006 | 01:51 PM
snowball's Avatar
so i think i may have found the leak
would this do it?
looks like it was leaking on the right side.
Queppa
Nov 18, 2024 03:47 AM
Azevedo
26
Mar 1, 2019 09:19 PM
Th0m4s
Feb 26, 2019 02:04 AM
