Power FC Greddy 3-bar pressure sensor?
Just a thought....
http://www.mohdparts.com/emanage/pre...sor/index.html
Greddy sells their 3-bar pressure sensor separately - you can also buy the harness for it and everything. Might be a good PFC upgrade to replace the stock MAP sensor.
The real neat part of it is the 60mm Greddy peak/hold/warning boost gauge uses the same sensor. So, if you were running that gauge, you could simply tap into the output signal from the gauge to use as your MAP signal. The above webpage has the voltage-to-pressure scale for the sensor.
BTW, the sensor is $99. It's a nice, quality, compact sensor too.
Dale
Dale
Originally Posted by DaleClark
Just a thought....
Dale
Dale
Nice! I wish I would have known this I have the GReddy boost guage... I ended up buying the Apexi map sensor for my power fc
troym55
23
May 25, 2016 12:42 PM
