Should I rebuild my engine??
Old Feb 13, 2002 | 04:25 PM
SaabGuy's Avatar
There is absolutly nothing wrong with it.
Still has power, idles perfect, 1q oil every 3k, no drips, passed emissions, clutch good, no flooding.
Everything seems perfect.
142k original miles.
Should I?? Or should I wait till it pops?
BTW I have time cause its off the road, winterized, soaking in ATF.
Old Feb 13, 2002 | 04:26 PM
RETed's Avatar
No reason to unless you got the money and can afford the downtime on the vehicle right now...
-Ted
Old Feb 13, 2002 | 06:17 PM
Kurgan's Avatar
Gaijin Racing
I tend to agree with Ted... but, think about it a bit....
A T2 with 142,000 miles on the stock block and still running not necessarily a common find. It will probably go, eventually... when it goes, it will probably take a rotor housing with it....
if you do it now, you won't have to replace any housings... but if you wait for it to pop (hell, it might not pop), you will most likely be spending a lot of casholla.
Old Feb 13, 2002 | 07:13 PM
cash money's Avatar
Old School Member
i think housings should be replaced anyway, so i would wait till it goes
Old Feb 13, 2002 | 07:26 PM
vaughnc's Avatar
knowledge junkie
go get a mazda rotary engine compression test and see
Old Feb 13, 2002 | 07:33 PM
Erik's Avatar
Best of both worlds
depends on your funds...if you have the Saab as the daily driver...and you're saving some money on the side for the T2...i'd wait and use it for what its worth...and when the time comes you'll have extra money for new housings...
who knows...maybe you'll never "really" notice any difference between new and used housings...but maybe it would be better peace of mind knowing you have all new components to the engine...
i'm sure you'll be fine for a while though...after a nice ATF soak...and the fact that it idles fine...doesn't flood, and revs up great should be a sign you'll have lots of fun with it before the time comes
Old Feb 13, 2002 | 09:33 PM
SaabGuy's Avatar
Sweet! Its just that I have been seeing a bunch of people in this forum with motors poping within the last few weeks;
But I guess people came to the forum when they expirience problems.
I think i'll let it pop, shouldnt take too long with a dp and presilencer.
Speaking of poping, anybuddy wanna take a stab at the HUGE whitehead under my left eye? (See avatar)
gtcd
30
Aug 19, 2015 02:44 AM
