streetable turbo for ported 13b?
Old Apr 26, 2006 | 10:35 PM
flight_of_pain's Avatar
its supposed to do that
i am running a large port 13b and am looking for a streetable turbo on a budget. i am only aiming for 300-350 horses, but a broad torque curve and an early spool. the car is my DD but also see weekend racing(auto-x, road course). how small is to small for a hot side a/r .6? .7? i have searched and waded through a ton of threads, but didnt seem to be coming up with many answers.
isaac
Old Apr 27, 2006 | 12:48 AM
Iwan's Avatar
my personal recommendation to you is to run a T04E with 60 comp and A/R of at least 0.84 as you engine has been ported. Also an option is the Mitsu (Greddy) TD06SH-25.
REgards
Iwan
Old Apr 27, 2006 | 12:59 AM
fastrotaries's Avatar
W. TX chirpin Monkey
I dyno this Fri...with the same goals as you...I'm more concerned with TQ than HP. I'll keep you posted.
Old Apr 27, 2006 | 08:05 AM
Broken09's Avatar
I am becoming...
What's your budget. Telling us that will help in pointing you in a good direction
Old Apr 27, 2006 | 08:20 AM
my budget at the moment is a couple hundred dollars. i have a T03B that i was planning to build a twin setup with, but for simplicity i think i would rather go with a single.
isaac
Old Apr 27, 2006 | 08:31 AM
dhahlen's Avatar
FD Under Construction =P
isaac
A couple hundred for just a turbo? or for the turbo, manifold and wastegate?
I'd say you need AT LEAST $600.
Old Apr 27, 2006 | 09:26 AM
EL5Letra's Avatar
Shut Down The System
60-1
Engine stand ready
Aug 14, 2015 10:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
