Turbo a 12a
Old Apr 25, 2006 | 02:49 AM
857rotarysteve-0's Avatar
Turbo a 12a
Is it possible? Where can I get the kit? Hit me up.
Old Apr 25, 2006 | 10:27 AM
SirCygnus's Avatar
whats going on?
its not that simple. and no, kits are out of the question.
Old Apr 27, 2006 | 02:24 AM
timmybighands's Avatar
Bad A55ed Hands
Sure, it's possible. I'm doing it - so are several other 12a owners on this very forum. There arent any kits, as has already been stated.... but it's not THAT hard to boost a 12a. Here's a REALLY rough idea for you:
Use a stock manifold and turbo off an FCTII and buy an RB flange to use as a spacer so that the housings clear your intake manifold. Then notch out the bolt-holes on a stock FC manifold to line up with the RB flange. Tap your oil pan for an oil return line, and get your oil pressure line from the stock oil pressure sensor location. That takes car of MOUNTING the turbocharger, which is what you seem to be asking about, mostly.
You'll have to custom-fab all your boost piping from the turbo to a rig-to-fit intercooler, and then to the carb. Your carb will need to be boost-prepped to keep the floats from colapsing under pressure, jetted and tuned to your new specs, etc... A reliable setup depends HIGHLY on supporting mods. Your stock fuel system is 100% inadequate. You'll replace the pump, filters, and likely the lines as well.
You'll need a custom exhast setup from the turbo-back too... I'm tired now - but there's more to do than that. But at least you have a good starting point now. Start rounding up parts to get you to that point, then come back for more questions. Even with everything done right, I wouldnt throw more than 5-6psi on a STOCK 22 year old block. You'll need to freshen it up with a good rebuild first too...
Old Apr 27, 2006 | 06:45 PM
diabolical1's Avatar
sure, you can.
there is no kit (that i know of). visit the archive in the Gen I forum, there is a great writeup by moremazda.
The1Sun
Mar 18, 2018 11:08 PM
Josh83rx7
Sep 2, 2015 05:57 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
rx7brandon
Aug 16, 2015 10:55 AM
