294rwhp Low?
Old Apr 23, 2006 | 08:11 PM
RenofHeavens's Avatar
Famous Phil's Cheesteaks
294rwhp Low?
Garret T04, 60 trim, .81 A/R at 10psi, 7100 rpms, I made 294.00. Does that seem low for a S5 High Compression Street ported engine? AFR's were in the 12's. IIRC the tune is for 15psi, this is what the previous owner said. I couldn't get my Profec S dialed in correctly so I left it up to the wastegate. Which brings me to another point. Wastegate opens at 15psi...then drops down to 10? Huh?
Mitch
Old Apr 23, 2006 | 08:24 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
timming? what rpm did you make the hp? do you have a sheet?
Old Apr 23, 2006 | 08:36 PM
I got a sheet, I'll have my roomate upload it as soon as he can.
7198rpms was the number, sheet shows it pulling until I let off, so maybe I could have pushed it further but I wasn't sure of the AFR's. As far as the timing, I cannot be for sure since the car was built by a shop, and I purchased it from the owner who broke the engine in and then sold it.
Old Apr 23, 2006 | 09:11 PM
FD Rey's Avatar
I brake boost
You went to that dyno day which uses a Mustang dyno. Mustang dynos read lower then Dynojets. Your car makes more power then 294rwhp. You may also have some sort of boost problem if you wastegate opens at 14psi then it drops to 10. I made 336rwhp at 10psi on my stock REW with a 60-1. You're probably right around there on a Dynojet.
BTW, I saw you on University on Friday. I was my truck going Westbound.
Old Apr 23, 2006 | 10:04 PM
Ahh sweet thankls for the info Rey. Yup, I live at Goldenrod and Aloma. I was headed to Famous Phil's then, turned the corner onto University and gave a little blip of the throttle, those damn rear-toe eliminators make the car slide a little to easy :-P
I failed to mention when I ran on the Dyno today I had my Profec turned off. Could the wastegate be having troubles? Spring maybe? The next time you are planning to go to Fuego's to work on your FD shoot me a PM, I want to stop by there and get the full specs on the turbo and the rest of the car since it was built there, meet a fellow club member and see what kind of beast you're working on now
Old Apr 24, 2006 | 11:14 AM
FD Rey's Avatar
I brake boost
No problem man. I'll be there a few days this week to drop in the motor. I should be there Tuesday after 3pm.
Old Apr 24, 2006 | 01:44 PM
After Wednesday I can show up, I just had some metal removed from my cornea. I am cleared to drive after I go see the doc Wed morning. I hope you're using safety glasses when needed
Old Apr 24, 2006 | 08:07 PM
FD Rey's Avatar
I brake boost
I won't be there Wed, but I'll be there Thrs. Anyways, back on topic. Is your boost hitting 15psi then dropping down to 10?
Old Apr 24, 2006 | 09:14 PM
Yes, its like "swoosh" hits 15psi, wastegate opens, and boost lowers to 10 and holds steady. This is with the profec turned off.
Old Apr 27, 2006 | 05:01 PM
robrxray's Avatar
ROBRXRAY
hey mitch, good job on dynopull, you can dyno tune which is different and that should be able to tell you wattup. it is more expensive, so if a couple of us get together, maybe it would lower cost. i liked your setup[turbo]. i wish i could of dyno but maybe i would have been disappointed or not. going to marc's do you still need parts? call mike or josh and let me know today. rob TII turbonator
Old Apr 27, 2006 | 05:11 PM
SPOautos's Avatar
Hey, where did my $$$ go?
the boost problem could be a few things.....
boost leak from a coupling or the bov
exhaust leak between the engine and turbo including faulty wg
if it has a 15psi spring in it and you dont have leaks on the pressure side then you prob have a exh leak between engine and turbo
Stephen
Old Apr 28, 2006 | 06:37 PM
RexRyder's Avatar
I made 305WHP @ 17PSI on 95 degree day. Same turbo except it had .96 exhaust housing. And oh yea, the motor was blown.
Old Apr 29, 2006 | 02:53 PM
Something strange happened last night. I turned my Profec on high boost and the wastegate opened at 17psi, I let off immediatly. I then switched to low boost setting and hit 20psi, WTF?
Profec or Wastegate failure?
How do I check a leak between the engine and the turbo?
Old Apr 30, 2006 | 02:33 PM
FD Rey's Avatar
I brake boost
Dude, I bet your boost controller is not hooked up correctly. Bring over your car to Fuego's on Tuesday after 3 if you can. I'll be there.
Old Apr 30, 2006 | 05:48 PM
Okay, I'll try to make it, thanks.
Old May 2, 2006 | 12:49 PM
fastrotaries's Avatar
W. TX chirpin Monkey
I made 302 RWHP and 225ft/lnls of TQ with the same turbo at 14.3 psi. The TQ thought starts off at 3,200 RPM's and goes to redline. I definitely need a bigger compressor. This was at CFT's mustang dyno.
Old May 2, 2006 | 12:53 PM
KeloidJonesJr.'s Avatar
strictly business
Pretty good for a FC if you ask me.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Jmpabon93
Sep 30, 2015 04:57 PM
