Removing TII airpump question
Old Feb 12, 2002 | 02:29 PM
FEDREX's Avatar
"Just Looking".......
What do I need to know about removing this extra baggage? I have the block off plates for air line that used to feed cat and also plate for ACV but it seems I saw a post about a dual alternator pulley when not running airpump.
Do I need to do something different with my belts since the airpump will no longer be on the car?
Old Feb 12, 2002 | 02:35 PM
Grimlock's Avatar
a buddy of mine took his out (gslse) only running 1 belt. he say its fine. i would think on a TII (high boost) you gonna need that extra belt to prevent slipage. why take the chance. if you run 1 belt then it starts to slip when your gunning the rexy you risk overheating, because the water pump will miss the extra belt, right.
im waiting to get the dual alt. pulley before i take off the air pump. i cant wait cause that freakin thing squeels like a bitch sometimes, lol
Old Feb 12, 2002 | 03:03 PM
BoOsTin FD's Avatar
Powered by** Rotary
Is that true about belts that they will slip?? I took my air pump, only air pump, i'm running 8 psi now untill i get my downpipe, which is on the way. So will it really slip or what??
Old Feb 12, 2002 | 03:12 PM
FEDREX's Avatar
Where are you getting it from?
Old Feb 12, 2002 | 03:23 PM
87jap951's Avatar
Ted told me awhile back that you DO need the dual alt. pully when removing the air pump. I put it on both my T2's and they worked very well!
Old Feb 12, 2002 | 03:41 PM
BoOsTin FD's Avatar
Powered by** Rotary
Where can i get that pulley cheap??
Old Feb 12, 2002 | 03:44 PM
If you run an Electric fan it does'nt slip to much but i'd fit a Duel Belt for Saftey as that belt drives the Water pump.
I've done the Mod and to be honist it did'nt make that much diffrence, the first thing i noticed is my Idle droped.
Old Feb 12, 2002 | 05:09 PM
BoOsTin FD's Avatar
Powered by** Rotary
Grizzly where did you get yours?
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
