Dead engine?
Old Feb 12, 2002 | 02:15 PM
Juan's Avatar
Im a tall midget.
Dead engine?
I posted this in the General Rotary Tech section. Seems like no1 goes in there. Here it goes..
I got my hands on an 86 GXL (Im going to swap the engine from my other fc into it). The engine didnt have oil in it (since it came from a junkyard). Dont know if the lack of oil caused something to dry up. Today I tried starting the engine in the GXL to see if it works. It just cranked over pretty fast. I squirted some ATF into the BIG vacuum hose on the dynamic chamber and its sitting right now. I dont have a compression tester so I cant test it. How can I tell if its low on compression? How can I try to get it running? Sorry for the long post.
Old Feb 12, 2002 | 02:20 PM
Josepi's Avatar
Despise Enmity
Cheap way, pull spark plugs, and put an index card or your finger over the hole and feel for air coming out. Should be even.
Old Feb 12, 2002 | 02:21 PM
FPrep2ndGenRX7's Avatar
Verify its getting fuel, air and spark. Check the guage for fuel quantity, verify no rats nest in intake. Put some fresh plugs in it. Even if ifs low compression it may still start but won't have any power. There are numerous things that can keep it from running and these are just the very basics.
Good Luck.
Old Feb 12, 2002 | 07:45 PM
Juan's Avatar
Im a tall midget.
how do I check for fuel? I emptied the gas tank and put some fresh fuel in it. I checked for spark and its good on both coils. I tried turning it over again and it sounded a little bit better with the atf in it but still nothing. So I just left it alone :p
Old Feb 14, 2002 | 06:15 AM
chubbrx7's Avatar
try to push start it that was the only way mine would start- have a friend with a car push you about 20 to 30mph until it starts-keep it in second gear
streetlegal?
Mar 17, 2022 02:46 PM
highspeedrider
Sep 8, 2015 07:55 PM
Microtech
Aug 23, 2015 11:04 AM
