Can someone with a 89+ T2 do me a big favor?
Old Feb 11, 2002 | 09:54 PM
pp13bnos's Avatar
Pineapple Racer
Could you measure the "in" side of the mass air flow meter, and the "Out" side? The inside diameter would be nice
Some peole say that the 89+ T2 and n/a cars use the same meter...but others say the T2 has a larger one....
Thanks, CJ
Old Feb 12, 2002 | 01:33 AM
fastrotaries's Avatar
W. TX chirpin Monkey
3" in /out outside diameter. if you need more info then hold on or PM me. it's too cold out right now.
Old Feb 12, 2002 | 04:46 AM
choritsu-shi's Avatar
They're pretty much identical on the outside... only the shape of the plunger, inside the AFM is different. The Turbo has a round, dome like shape plunger and the NA plunger comes to a point, shaped more like a cone.
Old Feb 12, 2002 | 07:08 AM
Josepi's Avatar
Despise Enmity
Strange the inlet to mine was 2.5"...TII too...
Old Feb 12, 2002 | 07:29 AM
here it is...
Old Feb 12, 2002 | 07:45 AM
its actually 8cm (3.15")out, 6cm (2.36") in. but you dumbasses dont measure metric so you lose some accuracy by rounding to whole numbers!
Old Feb 12, 2002 | 07:50 AM
Josepi's Avatar
Despise Enmity
Well here in america, what we measure is correct, otherwise we'd be using metric!!
JK!!
Unfortunately, all the aftermarket air filters i seem to find...are in ASE measurements, so it's better to get a 2.5" diameter flange (rubber w/clamp) that can be tightened down to fit exactly.
cook11
V-8 Powered RX-7's
Oct 2, 2015 11:52 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
