anyway other then airtools to remove this?
Old Apr 17, 2006 | 03:48 PM
Spirit Rx-7's Avatar
rotard
well, i broght some used agx's and it came wit springs. And now I want to take it out and put on my rsr springs. But, the rear strut bolt seems to move along as i use a ratchet. Seems like the only way to get it loose is to hold the stud with a vise grip, but i wouldnt wanna strip the stud. So any other sujustion? heres a pic incase noone knows what im talkin about. The stud itself moves along as i twist that bolt.
ohh yea, eventhough the pics make it look like the stud has two flat spots, it only has one flat spot!
Old Apr 17, 2006 | 04:05 PM
SPOautos's Avatar
Hey, where did my $$$ go?
I've only used a air tool so I cant really comment on if hand tools will work good....HOWEVER, I did want to make sure you are using a spring compressor while doing this. You might already be but I just wanted to make sure because its VERY dangerous to remove that bolt if you dont have a spring compressor keeping the springs from expanding out. Without one they will uncompress and take your head off. You can put down a fully refundable deposit at Auto Zone and rent one for a weekend.
I know that doesnt answer your question but I just wanted to make sure you were doing this correctly.....which you very well might be.
Be safe,
Stephen
Old Apr 17, 2006 | 04:12 PM
rotard
of course, i've always been using a spring compressor. Not sure how long autozone lets me borrow it for, but i've had it since thursday, and im done wit the front. just that this rear bolt is givin me a hard time, and i want to get this done already. hate it when my suspension is half assed.
Old Apr 17, 2006 | 05:19 PM
Narfle's Avatar
Rx7 Wagon
youre gonna need an airtool if its sticking most likely.
Old Apr 18, 2006 | 03:47 PM
rotard
damnit, i need an airtool. And its not really sticking, its just that the nut spins along with the stud.
Old Apr 18, 2006 | 04:17 PM
Mahjik's Avatar
Mr. Links
Yep. Just run them by someplace like Midas. They'll knock it off for you and probably not charge you anything.
Old Apr 18, 2006 | 04:21 PM
jgrewe's Avatar
GET OFF MY LAWN
That's a nyloc nut on there doing the job it is designed to do, not loosen up. Since you are saving the strut insert you will need an impact wrench to get it off.
Erosangel
Sep 18, 2015 04:06 PM
Steelwheelz
Sep 15, 2015 03:22 PM
