has anyone else seen this? 1 rotor go kart engine
Old Apr 12, 2006 | 11:09 PM
RXBeetle's Avatar
http://www.nova-racing.com/nova_gb/index.htm
http://www.karting1.co.uk/wankel-kart-test.htm
slap that on a go-ped hahaha
Old Apr 12, 2006 | 11:34 PM
crispeed's Avatar
'Tuna'
A couple of friends were at the local speedway here or as it is known 'Homestead International Speedway' and they brought one out to demonstrate it. All I can say was that everyone was blown away from the performance of the thing. My friend was there with his shifter 125cc and could not believe that such a small motor could harness that much power. The guy was lapping the field after about two laps. My friend is aware of the rotary motor and what it is capable of but was still freaked out about the performance. I told him you would not believe how easy it is to almost double the power of the motor without even having to spend a fortune.
Old Apr 13, 2006 | 12:29 AM
Black91n/a's Avatar
Check out this Wankel go kart. It has 10 times the power of that one!
http://www.swissrocketman.com/ete10.html
Old Apr 13, 2006 | 04:47 PM
eriksseven's Avatar
Make Money.
I wonder if the Atkins production 1-rotor engine could be mounted in a go-cart...? They're designed for water-craft.
Old Apr 22, 2006 | 12:08 AM
HITMANEM2's Avatar
i'm also pondering that as well...
Doesn't Atkin's put out 100hp??
that's enough for a fsae car which I want to build
Old Apr 22, 2006 | 01:01 AM
Mazda_Power's Avatar
I just want to drive it.
You do FSAE too? Cool.
Old Apr 23, 2006 | 04:05 AM
HITMANEM2's Avatar
yup but i know rotaries aren't allowed which sucks but i want to build one just for the hell of it
question is which transmission to use
Old Apr 23, 2006 | 09:10 AM
RXBeetle's Avatar
Snowmobile CVT and keep that bad boy pegged at 8K
Single rotor PP with a bike carb and a big stinger pipe, no baffles.
Scare the competition into submission.
Old Apr 23, 2006 | 04:44 PM
HITMANEM2's Avatar
rxbeetle thanks for the info
are there any pictures of this setup floating around on web?
what would you use for fuel control and ignition timing?
i'm thinking about Megasquirt
Old Apr 23, 2006 | 06:18 PM
RXBeetle's Avatar
http://evilallianceracing.com/ipw-we...SAE05/IMG_1629
Not a rotary, but these guys are runnin a megasquirted turbo charged B&S lawn tractor engine. The guy on that team posts as gielamonster on http://www.grassrootsmotorsports.com/ message board
I don't think any racing organization would let you run in thier classes but it would be an absolute freak of... mechanics in all the best ways. Good luck on finding sticky enough tires. To put it in perspective the gixxerkart has just over 100 hp and is almost an unusable amount of power http://www.gixxerkart.com/
Old Apr 23, 2006 | 07:08 PM
user 893453465346's Avatar
Red Pill Dealer
The link in the first post says 4 STROKE WANKEL. I would like to know more. How do they do that?
Old Apr 23, 2006 | 08:03 PM
RXBeetle's Avatar
as in:
intake
compression
combustion
exhaust
I'm assuming the XR-50 does it the same way a mazda rotary does. The rotary is technicaly a 4 cycle engine. Most people use "stroke" interchangably with cycle because in a piston engine the stroke/cam determines the cycle. The only difference is that a wankle is doing all 4 at the same time.
Old Apr 23, 2006 | 10:16 PM
Red Pill Dealer
OK. I think of the combustion in a Wankel as 2 stroke. I thought they had something new.
Edit for clarity: Even 2 strokes use all 4 cycles. I am surprised that it could be compared to a four stroke engine. Is this because they are using side ports like a Renesis? I bet they are.
Old Apr 23, 2006 | 11:43 PM
RXBeetle's Avatar
Fresh gases initially flow through one end plate, stream through the rotor, bearings and shaft cooling and lubricating, before passing into the combustion chamber through the opposite end plate.
This is similar to a two stroke using the premix to lubricate the bottom end. In the XR-50 they are also using the premix oil/gas to cool the rotor which is done with engine oil in RX7s. So it's side housing intake. I'm not sure about exhaust though, they brag about low emissions which would lean toward a side port but I see the exhaust system they show for the XR-50 is perfectly round which makes me think regular ole hole in the housing, perepherial port exhaust.
Either way, it's stinkin cool and when I'm old and senile I want one on my Rascal
= King of the nursing home 500!!!
Old Apr 24, 2006 | 06:51 PM
Red Pill Dealer
And I'll be with ya brother!
Old Apr 25, 2006 | 01:38 PM
SureShot's Avatar
Seduced by the DARK SIDE
Me too - only with a cut-out for that big-*** muffler
MoTeC
Sep 10, 2015 07:58 PM
