engine swap.. not sure if interchangeable..
Old Feb 11, 2002 | 09:29 AM
mel86rx7na's Avatar
I have a 86NA(automatic trans) getting ready for an engine swap, my replacement engine, coming from 88NA (manual trans), will it work on my 86NA? I was told by the guy in the junk yard that because my 86NA is an automatic the 88NA is not compatible with mine. Is he right? I want to convert it to manual but my wife drives this car most of the time and she want automatic so it is staying automatic. Or should I stick to 86NA replacement engine? Any input will be appreciated.
Old Feb 11, 2002 | 09:34 AM
VetteKiller's Avatar
I think that will work fine. You might need to make some minor adjustments but as long as the engine you're getting is just a shortblock I think you'll be ok
Old Feb 11, 2002 | 12:42 PM
Josepi's Avatar
Despise Enmity
86-88s will be a straight swap. smack your local junkyard worker. if it was an 89 it wouldn't though...
Old Feb 11, 2002 | 04:26 PM
4rxz's Avatar
did it, work out fine
just use the short block, remove the pilot bearing with the tool. it is almost impossible without it, i did chang the front counter weight but should be ok.
only problem is i get terrible gas miles, but its because i drop the tranny
Old Feb 12, 2002 | 12:45 PM
mel86rx7na's Avatar
Anymore words of wisdom out there? I'm getting ready to pull the 88NA out of the donor car this weekend so i want to be very sure before I tackle this one.
Old Feb 12, 2002 | 01:01 PM
Coolidge's Avatar
It will definitely work. All 86-88 NAs have the exact same engine
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
