West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
EXHAUST LEAK - coincedence? i think not
Old Apr 12, 2006 | 12:13 AM
RX7_Fanatic's Avatar
R.I.P. DAVE
So when i had my clutch fork replaced, the guys at RRR had to literally hang on my downpipe to move it out of the way to get the transmission back into the car...i said thats probably not a good idea, but they did it anyhow "it'll be fine" response.
So now i have an exhaust leak right at the turbo, what should i DO?!?
how much damage could hanging a 150 lbs person from the DP do?
how far should i go? fix the leak or replace the turbo cause who knows what else is messed up...????
Old Apr 12, 2006 | 12:51 AM
trainwreck517's Avatar
Rx-hippie
V band, or stud type? If just a stud type downpipe.. replace the gasket and retorque.. that should bo it. If its a vband.. something might have got tweaked.
Old Apr 12, 2006 | 01:11 AM
R.I.P. DAVE
stud but still...hanging from it
Old Apr 12, 2006 | 01:18 AM
jhammons01's Avatar
Carter 2.0
Go to Fantasy muffler Western and Manchester. They'll have you fixed before you can ask how much....and then they'll only charge you $20 bux. Those guys are insanly fast and cheap.
Old Apr 12, 2006 | 01:26 AM
misterstyx69's Avatar
Retired Moderator, RIP
I would take the car back in..They Caused the leak ,they should fix it..why should you fork money out for some **** hangin off your Exhaust,..In my Opinion they "EFFED UP"..and you should bring it back to Either fix what THEY caused..or Hand them a bill for it ..(Jhammons01 has a good suggestion too..if you don't want the "hassle"..)..Good luck RX7_Fanatic..
Old Apr 12, 2006 | 09:13 AM
Rx-hippie
If you get it done, just make sure those ******* don't weld over the leak and call it a day.. I seen catbacks welded to down pipes... and I wouldn't surprised if those ******* tried to weld the downpipe to the turbo. So becareful where you take it too.
Old Apr 12, 2006 | 04:57 PM
socalrotor's Avatar
Tell louie and sisco to FIX THE ******* LEAK. Socalrotor knows where BOTH of them live. Hit me up if you need help.
Old Apr 12, 2006 | 05:59 PM
AcidAngel7477's Avatar
We're All Fkd..
^yeah^
:aa:
Old Apr 12, 2006 | 07:05 PM
R.I.P. DAVE
its probably just the gasket guys, the manifold is a cast HKS one, i was just overreacting. I talked to Troy at XS and he was really cool and even hooked me up with a power pack II ignition amp while i was there =)
doesnt change the fact that it was dumb to hang off of it but its not that serious i suppose, unless i replace the gasket and the leak is still there...O_o
Old Apr 12, 2006 | 07:16 PM
socalrotor's Avatar
BTW Knowing what I know about the rr&r crew...........150 lbs is far too light. try closer to 275 lbs. Not even nick is under 175 IMO!!!!!!!
Old Apr 12, 2006 | 10:36 PM
jhammons01's Avatar
Carter 2.0
^^^pwn3d
Old Apr 12, 2006 | 10:54 PM
R.I.P. DAVE
haha kevin teh intern is a pretty skinny dude, he was doing the monkey act.
Old Apr 13, 2006 | 12:40 AM
socalrotor's Avatar
INTERN= free labor without a clue. Tell him to BACK THE **** UP, if you have to, or sisco will eat him carne asda style!!!!UUUUMMMMMM CRACKA be tender.
13
Jan 9, 2018 11:19 AM
rotor_veux
Sep 3, 2015 07:10 PM
