na fc dyno
Old Apr 12, 2006 | 12:08 AM
adamxevil's Avatar
delta peanut
na fc dyno
the motor's pretty much stock except for a k&n filter and a single pipe 2 1/4" exhaust, which is more restrictive than stock. these numbers are after light tuning with an s-afcII. i had some miss or break-up past 5500 so...
hp: 109 @ 7100rpm
tq: 101 @ 3700rpm
wait for the rb road/race header and no cat numbers...
Old Apr 12, 2006 | 03:41 AM
RotaryEvolution's Avatar
Sharp Claws
those numbers are pretty low even for a stock car, what dyno was it?
Old Apr 12, 2006 | 04:01 AM
eriksseven's Avatar
Make Money.
5th and 6th ports are probably stuck or something.
Old Apr 12, 2006 | 08:31 PM
adamxevil's Avatar
delta peanut
we've got a lot of work to do...
it's a dyno-mite chassis dyno.
up past 5500rpm i started to miss really bad, i haven't tracked it down yet. i'am throwing a pressure sensor code also. so, that's got to kill the numbers a little bit.
i know the exhaust is cutting it down too. i'am putting together an exhaust made up of a racing beat road/race header w/ extra long primaries, then y'd into a 3" pre-silencer, then y'd back to two mufflers. it might sound iffy, but we'll see what it makes.
oh yes, i believe you are correct about the 5th and 6th ports sticking. the rear port particularly.
anyway, i'll get that stuff fixed (hopefully my lm-1 will have gotten here by then) and then we'll see what it puts down.
i will also be removing the front plates off the throttle body and then porting it... should be fun.
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
