Where can I buy new vacuum lines??
Old Feb 11, 2002 | 07:56 AM
Rxmfn7's Avatar
Do a barrel roll!
I just wondered if there was somewhere I could order new vacuum lines for my rex. Does anywhere make a set especially for our cars, like all cut to lenghts and bent correctly like stock?? I know a couple places sell silicone vacuum lines, but they are all just rolls of it, and all need cut and fitted, just wondered if there was a car-specific kit anywhere. I want silicone, preferably in some purty colors, but Im not picky, just want new ones. Thanks.
Old Feb 11, 2002 | 08:11 AM
Samps's Avatar
mazdatrix has what you need. it is not cut and not bent but it is silicon so it bends like spagheti. My intake took 8 feet to change all of the vacuum lines except for the lil ones on the celenoids. So 10 feet would do the whole thing, but the celenoid ones are dangerous; because you will break off all of the nipples and end-up paying a ton of money for new ones. So 8 feet and some wire snips and you're set. www.mazdatrix.com I think it's in the misc. parts section with all of the gasket sealer stuff and fluids. it's like $3.00 a foot
Old Feb 11, 2002 | 08:16 AM
snoopster76's Avatar
Twisted Girl Chaser
one nice thing about cutting yourself, is it can clean up the engine bay some for the ones around the engine, you can route them any way you like. esp if you have mods.
Old Feb 11, 2002 | 08:23 AM
Rxmfn7's Avatar
Do a barrel roll!
I dont like cutting myself it hurts.
j/k..sorry Im in a silly mood
Old Feb 11, 2002 | 08:59 AM
Audiofight's Avatar
HMV-3.5MM........HOSE VAC 3.5MM BLUE...SILICONE (1 FOOT)...... $ 2.00
There you go. I, too, will have to consider this in the near future.
Old Feb 11, 2002 | 09:26 AM
Rxmfn7's Avatar
Do a barrel roll!
Ok, but what about the different size hoses?? Like that big *** one that goes from the BAC around the TB to the air intake?? Or the three right in front on top, by the idle mix screw, theres 3 vertically, and the one on top is larger, where car I get these? Thats why I was asking about a car-specific kit.
Old Feb 12, 2002 | 06:35 AM
Rxmfn7's Avatar
Do a barrel roll!
Anyone with any imput on where I can get those larger lines that I mentioned above??
Old Feb 12, 2002 | 06:47 AM
Audiofight's Avatar
Not sure if they have them, but they sell multiple color vac lines:
www.horsepowerfreaks.com
I have to go to work, will check it out myself in detail later tonight.
Old Feb 12, 2002 | 07:30 AM
20B10AE's Avatar
Gone Darkside
their kit is designed for the TII, but www.hosetechniques.com sells a kit. . .
Old Feb 12, 2002 | 09:31 AM
SaabGuy's Avatar
Go to Napa. They sell silicon vac hoses in packages of 6' for $10 each.
They have all the sizes as well. The hoses are orange just to let you know.
Old Feb 12, 2002 | 12:08 PM
SureShot's Avatar
Seduced by the DARK SIDE
While you'r at it get a pair of bent tip long nose pliers. They make removing & installing the lines much easier.
Kyo
Apr 13, 2019 09:24 AM
dkwasherexd
May 27, 2017 04:51 AM
pzr2
Aug 15, 2015 08:29 PM
