what size clamps for vacuum and coolant lines?
looking to get some new clamps for some of my coolant lines and some of the vacuum lines in hot areas. i wan to buy some Machine-Screw Hose Clamps (like mini t bolt clamps) but dont know what sizes to buy. any one know what size to buy for 1/4, 3/8, 1/2, etc hoses? here are the size clamps avalaible.
15/64"- 21/64" 6.0-8.3
9/32"- 3/8" 7.0-9.3
5/16"- 13/32" 8.0-10.3
23/64"- 29/64" 9.0-11.3
25/64"- 31/64" 10.0-12.3
7/16"- 17/32" 11.0-13.3
15/32"- 9/16" 12.0-14.3
33/64"- 39/64" 13.0-15.3
35/64"- 41/64" 14.0-16.3
19/32"- 11/16" 15.0-17.3
TIA everyone.
9/32"- 3/8" 7.0-9.3
TIA everyone.
When I re-did all my fuel lines I used mini screw type clamps and noticed after a few engine heat cycles I had to tighten them all down again as they began to leak. You will note the factory hoses always use a spring type clamp that will always keep a constant pressure on the hose (as long as hose is still pliable.) I feel these spring clamps are best, especially in areas you can't get to to re-tighten once assembled. Anyone else?
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
