RX6 0-60 Times
Old Feb 10, 2002 | 10:10 PM
enuttage's Avatar
Chicharrones Rule!!
RX6 0-60 Times
Anyone running an Apex'i RX6 have any stats on what your 0-60 times are?
Or, if no one has timed it out, anyone have a relatively educated guess as to what said times might be?
-E
Old Feb 10, 2002 | 10:45 PM
JoeD's Avatar
im guessing mid-high 3 seconds. its all about traction.
Old Feb 11, 2002 | 12:51 AM
rmani's Avatar
if anyone can elaborate on that a little more to include 1/4 mile eta and trap speed i'd appreciate it.
Old Feb 13, 2002 | 11:58 PM
fastrotaries's Avatar
W. TX chirpin Monkey
RX-6 like the car? Apexi? what? someone please clue me in?
Old Feb 14, 2002 | 12:59 AM
rmani's Avatar
rx6 is a new turbo from apexi which has very little lag and can generate some good hp numbers.
Old Feb 19, 2002 | 11:48 AM
enuttage's Avatar
Chicharrones Rule!!
Bump.
Max, did you ever grab 0-60 times running your car (pre boost disaster)?
-Eric
Old Feb 20, 2002 | 01:58 AM
maxcooper's Avatar
WWFSMD
Originally posted by enuttage
Bump.
-Eric
No. But it should be about 4 seconds flat. Traction is the limiting factor, so I think it would be as much a test of your launching technique and tire traction as anything.
1/4 mile times and trap speeds would be a better thing to look at, but I don't have those either.
-Max
Old Feb 20, 2002 | 09:30 AM
enuttage's Avatar
Chicharrones Rule!!
Thanks Max. 1/4 mile is good to get also, but I'm just sort of curious what things are gonna be like off the line, on the street.
Old Feb 21, 2002 | 01:00 AM
maxcooper's Avatar
WWFSMD
Well, you can spin the tires in first gear at will, and probably second gear, too, if you don't have wide, sticky tires. Somewhere in the mayhem, you'll pass 60 MPH.
-Max
Old Feb 21, 2002 | 06:59 AM
enuttage's Avatar
Chicharrones Rule!!
Hee hee. Right now I've got Toyos on it. We'll see I suppose. I'm saving the Hoosiers for autoX work
-E
Old Feb 21, 2002 | 03:44 PM
7_HEAVEN's Avatar
Arkansas Razorbacks FTW
put on some Yokohama AVS Sport's THEY"RE SWEET!!
Microtech
30
Apr 23, 2016 06:37 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
20B Forum
Aug 19, 2015 01:47 PM
