turbo 88 rx7
Old Apr 8, 2006 | 02:42 PM
racamp's Avatar
turbo 88 rx7
ok so ive posted before about my car not staying on its still doing it ive changed the fual filter it doesnt putter anymore but just wont stay alive changed spark pluges and wires they needed to be changed but still wont stay on i have to give it gass to hold it at about 1500 or it will die if it goes under 1000 but if it does go below 1000 i can pump the gass to get it back up anyone help~!
Old Apr 8, 2006 | 02:46 PM
racamp's Avatar
one more thing
in the mornings when i start the car i have to pump it to keep it running if i just push the throttle it will putter then just die.
Old Apr 8, 2006 | 03:06 PM
BASTARD's Avatar
probably have an intake manifold leak. when engine is cold start it and run a water hose over it. when the water gets to the leak the idle should change.
Old Apr 8, 2006 | 03:23 PM
racamp's Avatar
the car wont stay idled.
Old Apr 8, 2006 | 03:29 PM
BASTARD's Avatar
so it wont idle or rev up?... if you can get it to run at 1500 RPM then adjust the throttle cable until it stays running
or get someone to sit in the car to keep it running
FD7KiD
15
Feb 26, 2021 10:12 PM
Kyo
Apr 13, 2019 09:24 AM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
