Couple of questions.....
Old Apr 6, 2006 | 08:20 PM
Robbo9's Avatar
I own a 1987 GXL
1.) Is it honestly necessary to keep putting top grade fuel in my car? I was advised to do this by my uncle, who sold the car to me.
2.) My owners manual says not to use synthetic oil. Does anyone know the exact reason why?
3.)I just replaced my clutch, and my clutch pedal seems to release awfully high. Is there any way to adjust this, or should I just relax, and go with the whole "every clutch is different" thing?
I figured I'd keep my post short and simple.
Thanks!
Old Apr 6, 2006 | 08:29 PM
DerangedHermit's Avatar
Originally Posted by Robbo9
I own a 1987 GXL
Ignore your uncle and put in 87.
Synthetic oils are alright, as long as they are clean burning (high quality/expensive). Cheap synthetics aren't good for the engine. Mazda was just covering their asses from people putting in cheap *** oil and then blaming then when their engines started sucking.
Old Apr 6, 2006 | 09:40 PM
rx7b13's Avatar
I own a 1987 GXL
i use castrol 10-w30 part synthetic
Old Apr 20, 2006 | 08:21 PM
Robbo9's Avatar
just wanted to see if anyone else could answer these questions. particularly the first one.
Old Apr 20, 2006 | 08:29 PM
Goofy's Avatar
1. The 7 is probably the only sports car where the owner's manual suggests using 87. I use 89 out of habit.
2. High quality synthetics are fine. This is discussed in the FAQ.
3. I believe clutches can be adjusted. I'm stuck with an automatic, so I don't know how, but I'm sure a factory service manual has the info you need. Also found in the FAQ.
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
yr6
Oct 4, 2015 12:23 PM
inMotion719
Sep 28, 2015 03:09 PM
