86 n/a block
Old Apr 5, 2006 | 12:35 PM
Michelob779's Avatar
86 n/a block
anyone have a close estimate for the size of this
im lookin for the smallest dimensions
an 86 n/a block with the bare minimum to run
it doesnt need an exhaust or emissions etc...
im tryin to make it as small as possible
Old Apr 5, 2006 | 01:37 PM
J-Rat's Avatar
Alcohol Fueled!
well, you need some form of intake. For size sake a carb would be the easiest. Once you get a carb you can yank all the emissions off and block it. That usually vastly slims up the motor.
Old Apr 5, 2006 | 02:13 PM
alright how do u go about setting up a carb on a
13b other then that
what r other options and or dimensions
Old Apr 5, 2006 | 03:32 PM
13BNUT's Avatar
what are you planning on using it for?
Old Apr 5, 2006 | 05:06 PM
i want to use my brothers old honda
motor cycle frame
and see if its anywhere near possible
to fit my n/a block on it
the whole bike mechanically intact
but the engine is fucked
so i thought hes not doin anythin with it
so....
Old Apr 6, 2006 | 12:04 PM
13BNUT's Avatar
Damn that is interesting but I can't see it working, but then again anything is possible.
Good Luck, and post lots of pics when you do your build up.
Old Apr 6, 2006 | 12:07 PM
Alex6969's Avatar
The Silver Bullet
i think the 13b will be too big, you'd still have to fit a tranny of somesort on there
Old Apr 7, 2006 | 11:16 AM
i could try and mount it sideways
and then match up a small motorcycle tranny to it
but i dont kno much about
the bikes just what ive seen on
american chopper .......
but anyways the only reason i even considered this was because
i have a friend that wants to buy my 86 n/a and hes dropping
a 350 in so he doesnt care if i take the engine and tranny
so i wanted to put it to good use
if not i might try and sell
it well see
maybe when or if i sell the car i can take the block and check to see
if its anywhere close to fitting
cook11
V-8 Powered RX-7's
Oct 2, 2015 11:52 AM
rxlevi7
Sep 26, 2015 07:28 AM
jarjarbinks
Sep 25, 2015 11:03 PM
MidnightOwl
Sep 25, 2015 10:24 PM
