Need help choosing correct wastegate springs
Old Apr 5, 2006 | 07:05 AM
Turbo_Rotary's Avatar
Major RX-7 Withdrawals
I just ordered a fully divided turbo manifold with dual wastegate runners. I'll be running dual Tial 38mm's, but I am a little confused on which springs I need to run in both. Will both wastegates see the total amount of boost (~23 psi), therefore needing the larger springs, or will both wastegates see only half the boost (~12 psi), needing only the smaller spring?
Old Apr 5, 2006 | 07:45 AM
dubulup's Avatar
development
both wastegates see the same pressure.
Old Apr 5, 2006 | 08:46 AM
pistonsuk's Avatar
Whether you run dual or single wastegates will have no effect on the spring you want to use.
Most select a spring based on the stiffest one they can run while stiff being able to run the lowest setting of boost desired. i.e. if you want to run 16-23psi of boost then get a 13-15psi spring. Assuming you are using a boost controller. Or, if not, just get a 20-22psi spring and use the adjustment screw on the top to tune it in.
Justin
Old Apr 5, 2006 | 08:09 PM
Thanks! I was a little confused about that stuff at first, but I think I'm getting it now.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Shainiac
Jul 17, 2019 02:20 PM
