tps readings
Old Apr 4, 2006 | 05:19 PM
evilfocus's Avatar
tps readings
how bad is it if the tsp reads 363 ohms in the idle position between terminals a and b? the fsm says it should be at 1000 ohms and between 4000 - 6000 at wot. at wot it reads 4750 ohms, which is within spec. my car has a serious lack of power through all rpms. would this explain it or would it be something else?
Old Apr 4, 2006 | 05:20 PM
evilfocus's Avatar
sorry, meant tps in th first line
evilfocus's Avatar
sorry, meant tps in the first line
Old Apr 4, 2006 | 05:25 PM
slpin's Avatar
7th Heaven
it means you have to adjust the little screw till it reads 1000
Old Apr 4, 2006 | 05:38 PM
evilfocus's Avatar
so its meant to go below 1000 ohms?
Old Apr 4, 2006 | 08:01 PM
evilfocus's Avatar
i thought it was only supposed to only go as low as 1000 ohms
Old Apr 4, 2006 | 08:43 PM
HAILERS's Avatar
HAILERS
YUP
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
Donald Hampton
Sep 17, 2015 03:13 PM
