Turbocharger question on T2?
Old Feb 9, 2002 | 02:34 PM
Is it ok if a turbocharger spins freely when I turn it and it doesn't rub anywhere or anything but when i kind of try to move the rotor back and forth a little bit, It moves maybe a milimeter or something like that? It kind of has a little play.
Is it a busted turbocharger or is it gonna work??
Old Feb 9, 2002 | 05:02 PM
ralph f cooke's Avatar
A millimeter might be a little much, but as long as it doesn't touch the sides when you try to push it againt one side and turn it, and as long as there is no axial play (in and out) it should be ok.
I have a replacement turbo for my TII, as I thought that I had too much play, but as I am getting full boost (actually too much boost as the fuel cut comes into play since I titted a bleed valve ~ 10psi) and there is no apparent smoke from the turbo bearings) I will hang onto the replacement until I need it.
ralph
Old Feb 9, 2002 | 10:05 PM
Ryde _Or_Die's Avatar
You could have it looked at at a local turbo shop and have it upgraded even.
Old Feb 9, 2002 | 10:56 PM
j9fd3s's Avatar
Community Builder
it can move bacl and forth a bit but you should not be able to move it in and out
mike
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
AXA
Sep 5, 2015 10:06 AM
