Haltech e6k to ntk sensor?
Old Mar 26, 2006 | 11:31 AM
93rotorhead's Avatar
e6k to ntk sensor?
Ok Iv been doing some searching and confused myself. First can the ntk 4 wire sensor be wired strait to the e6k without a wb controller. IF so does anyone have a wireing diagram of the ntk sensor(what color is what). I know how to wire it to the haltch. Or will I get the same results with the factory 1 wire sensor without the ntk hook to a wb controller?Does it make any sense to use the ntk 4 wire sensor if your not useing a wb controller?
Old Mar 30, 2006 | 09:16 PM
anyone?
Old Mar 31, 2006 | 05:10 AM
RETed's Avatar
You sure the 4-wire is a wide-band?
Someone told me all wide-bands are at least 5-wire?
4-wire is typically: heater +, heater -, sensor signal, sensor ground
-Ted
Old Mar 31, 2006 | 05:21 AM
RETed's Avatar
4-wire wideband?
Someone told me all wide-band UEGO sensors are at least 5-wire?
-Ted
Old Mar 31, 2006 | 05:47 PM
Well i thought it was a wideband but I could be wrong
Old Mar 31, 2006 | 07:58 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
3 and 4 wires sensors can be wired directly to the Haltech because they are narrow band. Some 4 wire sensors have been known to have ranges of more than 1v, sometimes from 0-2v, these sensors are still narrow band, but their scaling is different than your regular 0-1v sensors. Ive seen these types of sensors on VW/Audi cars.
If you have one of these sensors, make sure you know what their AFR to Voltage is so you know what its telling you.
All wideband sensors are 5 or 7 wires, and work from 0-5V, and need a controller to be wired up to the haltech.
Old Apr 1, 2006 | 07:38 AM
Thanks , I took another look at my sensor and it is a five wire so If I have to have a controller to make it work I think Ill just use my one wire sensor for now and save the other one for a later project.
Old Apr 1, 2006 | 06:45 PM
EFI Tech Wannabe
I recommed then that you get your self either a 3 or 4 wire sensors, they are more accurate and start working faster than the single wire, since they have to basically heat up with the exhaust to work.
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
