NA subframe on TII?
Old Feb 8, 2002 | 09:39 PM
20B10AE's Avatar
Gone Darkside
NA subframe on TII?
My friend went to change his front diff mount tonight and found that the diff mount was fine. He had broken the subframe itself. If you swap all the TII driveline components, can you use an NA subframe?
Old Feb 8, 2002 | 10:00 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Yes.
Old Feb 9, 2002 | 08:21 AM
20B10AE's Avatar
Gone Darkside
thanks, brad
Old Feb 9, 2002 | 05:44 PM
Gene's Avatar
10 lb. boost, 5lb. bag
erm, if you managed to break the T2 subframe you'll probably break the NA one (or the driveline) as welll... unless they're actually the same, are they?
Old Feb 10, 2002 | 12:41 AM
fLyiNgOuFeR's Avatar
i had the same thing happen to me! that sucks ******** dude. but i used a N/A subframe and it's holdin up fine. next time i break it tough i'm goin to weld that **** up. that particular mount is a bitch and likes to brake. ALOT!! i suggest u weld too. or make a metal mount and reinforce the mount on the subframe. good luck!!
Sethix
Nov 3, 2017 11:48 PM
MidnightOwl
Sep 25, 2015 10:24 PM
