Megasquirt FD setup in first gen sensor question
Old Mar 24, 2006 | 08:48 AM
mooseknuckle's Avatar
i need a 20b in my fb
Ok i have FD wire harness Fuel Rails Injectors 550 and 850 upper manifold with tps and temp sensors and fd throttle body. The fuel rails will be sitting in a custom carbon fiber manifold to connect it to my 12a 4 port. question is on the megasquirt rx7 faq it says that i need to change the bias resistors in r4 on the board and that the fd is "probably the same" does anyone know if i can replace the same resistors to use the stock fd sensors. planning to build a v3 board.
thanks for your time
Old Mar 24, 2006 | 10:05 AM
renns's Avatar
A check of the specs on the FD sensor will tell you. If it's temp/resistance characteristics match the earlier models, you can follow the directions directly. If not, you'll need to follow the general instructions at megasquirt.info. Either way you should be able to use the existing sensors.
Skeese
65
Mar 28, 2017 03:30 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
Marty RE
Aug 13, 2015 11:19 AM
