One piece 4 inch exhaust system?
Old Mar 20, 2006 | 10:15 AM
Bukwild's Avatar
We welded up the DP this weekend and I was wondering if it was a good idea seeing the vband came on and off so easy, would it be a good idea to keep the exhaust system one continuious piece instead of putting 2 flanges in the center i.e. where the cat back would bolt up to????
I was thinking that worst case I would add another 4 inch vband setup in the center section
After the DP I am connecting a 4 inch Magnaflow oval as a midpipe and then a 4 inch round Magnaflow on the end as the end can.
Sorry DP pics are so dark. My camera phone takes crappy pics when the battery is low.
Attached Thumbnails One piece 4 inch exhaust system?-4inchdp1.jpg   One piece 4 inch exhaust system?-4inchdp2.jpg
Old Mar 20, 2006 | 10:19 AM
Zero R's Avatar
Just in time to die
Bad idea, it becomes a pain when you have to remove it regardless of the single v-band.
-S-
Old Mar 20, 2006 | 10:27 AM
Bukwild's Avatar
yeah I thought about that. Anyone have 2 4'' flanges and a metal gasket they want to sell me then?
Old Mar 20, 2006 | 10:33 AM
Zero R's Avatar
Just in time to die
Just v-band the whole thing. Use some flex sections it will be fine. I offer that as a upgrade on some of our kits.
-S-
Old Mar 20, 2006 | 10:47 AM
Bukwild's Avatar
-S-
Sean where do you suggest placing the flex?
Old Mar 20, 2006 | 11:43 AM
Zero R's Avatar
Just in time to die
Next to the v-band clamps will work with some types. I would say it depends on the type of flex used. If you use the common ones the further from the flange the more range of movement you'll get.
-S-
Th0m4s
Feb 26, 2019 02:04 AM
astrum
24
Nov 15, 2017 08:44 AM
GrossPolluter
Aug 22, 2015 11:23 PM
