Any fender rubbing with 235/45R17
Old Mar 15, 2006 | 01:07 PM
Tripple 7's's Avatar
Ive done an exhaustive search anyone have any rubbing issues on the fender lip with 235/45r17 on the fronts.
Old Mar 15, 2006 | 01:12 PM
neofreak's Avatar
accept no imitations™
Depends on your offsets.
Old Mar 15, 2006 | 01:24 PM
Gamezilla's Avatar
Broken...always
Shouldnt you be doing 235/40 on a 17" rim. Its gonna throw your speedo off if you dont. Unless...you're getting it recalibrated?
Old Mar 15, 2006 | 01:35 PM
rynberg's Avatar
No. 235/45 17 is the correct tire size.
Old Mar 15, 2006 | 01:37 PM
Gamezilla's Avatar
Broken...always
So I should be running 245/50/r16 on my stock rims? I dunno why, but my car came with 245/45/r16's
Old Mar 15, 2006 | 01:40 PM
rynberg's Avatar
No....245/45 16 is a proper size for 16" wheels, just a hair smaller diameter than stock. A 235/45 17 will be about 0.4" taller than stock, which is an acceptable variance.
Old Mar 15, 2006 | 01:42 PM
SpeedKing's Avatar
Power Trippin'
That's correct. The '99+ FD 17x8 front wheels came w/ 235/45-17.
Old Mar 15, 2006 | 02:12 PM
ptrhahn's Avatar
Any FD with aftermarket wheels/tires has SOME potential for rubbing either the fender liner, or pulling the fender lip up front, particularly if it's lowered. Most aftermarket wheels don't come with the +50 offsets of the stock wheels, and you add a little extra diameter and width, along with lowered ride height, and there's potential that varies with each combo.
235/45/17 is the correct size. As stated, the '99's come with that size. Depending on wheel width, you might also try 245/40 or 255/40's as well. I'd always suggest getting the fenders rolled however. All you need is a good bump or transition with the wheel turned, and you've got a pulled lip.
Old Mar 15, 2006 | 02:22 PM
My biggest worry is pulling the fender lip, I just picked up some Borbets, 17X8 fronts and 17X9.5 rear.
Im gonna go with the 235/45ZR17 by yokohama AVS ES100, the back tires currently are 265/40ZR17 but im thinking of going with 275/40ZR17 when the tires are needed as the have 25%tread left and Yokohama dosnt make a 265/40ZR17 to replace the Kumho thats on it now.
I did buy a fender roller but am leary of cracking the paint and want to practice before I roll my fenders. but want to install tires now without majior worries.
Old Mar 15, 2006 | 02:28 PM
ptrhahn's Avatar
The trick to rolling without cracking the paint is to use a heat gun or similar to soften the paint... you don't want to overdo it though. I'd see if there's a shop around who can do it for you.
If you put them on, the places to be careful are when you're pulling in someplace or going around a corner with the wheel turned and there's a bump or transition... it'll be the inside wheel.
