Pop off valve?
Old Feb 7, 2002 | 12:51 AM
ek9220ps's Avatar
Question Pop off valve?
What are the pro and cons of pop off valves?
anyone has them?
Old Feb 7, 2002 | 01:01 AM
LT1-7's Avatar
John
I don't think there are cons but I know they benefit alot if you should ever have any boost spikes. I had one, but never installed it. I would get one for sure if I have another turbo car. You can set it at say 12psi and you will NEVER boost over that. Big insurance
Old Feb 7, 2002 | 03:26 AM
skunks's Avatar
I'm a CF and poop smith
its a great thing to have to prevent boost spikes but you should not used it to control boost regularly, it will kill your turbos (causing them to over spool/spool too fast)
Old Feb 7, 2002 | 10:01 PM
ek9220ps's Avatar
I juss want to use it to control boost creep
Old Feb 8, 2002 | 12:15 PM
dis1's Avatar
www.silverbulletrx7.com
Using a pop-off valve to control creep is a REALLY bad idea. It will cause the turbos to over spool just like skunks said. You need to port the waste gate or install a restrictor plate. Pop-off valves are good for spikes and insurance and that's it.
ls1swap
Jun 3, 2024 03:25 PM
renjiv2
57
Jan 25, 2024 03:34 AM
Rotafuzz
Sep 30, 2015 09:55 AM
