West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
CA smog?
Old Mar 11, 2006 | 05:06 AM
rotorybaby's Avatar
CA smog?
ok today went to go do a PRE smog test(in soCAL)the result was fail of course! the guy told me i needed a TUNE UP, O2sensor, and change the CATCONVERTER..he told me i only needed 1 cat converter!(is that even right 1 CAT)instead of 3 and it'll be ok! i was like NO WAY! let me think about it and come back!
anyway the result was at
15mph
HC=439ppm
CO-4.6%
CO2=11.7%
O2=0.1%
NO=44ppm
at 25mph
HC=187ppm
CO=3.7%
CO2=12.3%
O2=0.1%
NO=89PPM
i think the NO is ok but the rest needs help???
any tips? i search but i dont understand!
Old Mar 11, 2006 | 08:18 AM
Tournapart's Avatar
RIP Icemark
the suggestions sound reasonable. but do the work yourself
Old Mar 11, 2006 | 01:03 PM
rotorybaby's Avatar
what kind of part do i need to buy for the tune up?
Old Mar 11, 2006 | 10:19 PM
AcidAngel7477's Avatar
We're All Fkd..
well that depends, on what a tune up means to you....heres what it means to me
air filter, coolant flush, oil refresh, oil filter, spark plugs, spark plug wires, fuel filter, & O2 sensor..not hard work at all, if you need help ill be more then happy to do so....just let me know...
as far as the cat. goes your on your own....lol
:AA:
Old Mar 12, 2006 | 01:08 AM
rotorybaby's Avatar
:AA:
but do i only need one cat?
Old Mar 12, 2006 | 06:22 PM
twistedriver's Avatar
Finally I have LSD
You can pass smog pretty well with only one cat (main cat with the air pipe going to it). In fact i pass smog 3 times with just the main cat. I didn't know that my other cats was hollowed out untill i took the front cats off. Changing the o2 and air filter would also help if is orginal. There is a valve in the intake manifold where the air pump connects. That valve gets stuck and wont let the pump pump air to the cat. That may also cause the high gas readings. Good luck!!
Old Mar 16, 2006 | 03:42 PM
rotorybaby's Avatar
finally after changing 1 cat O2 sensor and drive the car for 1hr, to make cat very hot (smog guy told me to drive it for 1hr before coming to take the test) IT PAST at a TEST only facility. YAY! just wanted to let you guys know LOLz
Old Mar 16, 2006 | 03:58 PM
Good deal!
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
Erosangel
Sep 18, 2015 04:06 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
