antifreeze leak
Old Mar 6, 2006 | 09:00 PM
myxbuddy's Avatar
JDazzle
antifreeze leak
I rencently added antifreeze and i noticed that there is a hole at the top of the tank so when you fill up to that point it will leak out. I am guessing that that is so that you do not overfill? when i drive somewhere and park, and later return to my car, there is a spill of antifreeze underneath the vehicle. I am assuming that it is getting too hot or pressure is causing the antifreeze to rise and overflow through that same hole. is this possible? The strange thing is that when i added some today, and pulled into my driveway, the antifreeze leaked even though my engine was not very hot. can someone help me out?
Old Mar 6, 2006 | 09:41 PM
weetbix13's Avatar
hole at the top of the tank?
which tank?
filler neck?
air seperation tank?
overflow tank?
my guess is that you can't see the overflow tank from an untrained eye (no offence) so you're most likely talking about the Air Seperation Tank. that nozzle attaches to a hose that runs to the overflow tank. if not connected it WILL drop coolant.
Old Mar 6, 2006 | 09:46 PM
IRPerformance's Avatar
Sponsor
The overflow tank will leak if you put too much coolant in. It doesn't really seal where the neck meets the tank. Don't over fill it.
Old Mar 6, 2006 | 09:56 PM
bajaman's Avatar
Constant threat
You are putting way too much coolant in, just go by the dipstick on overflow tank, it has "full" marked on it.
If you are getting the coolant coming out of the overflow on a regular basis and having to add coolant, I'd suspect your Air Separation Tank has a bad cap. For some reason these things tend to NOT have a very long life, I've replaced several of them. What basically happens is they get to where they leak and the system won't pull coolant back OUT of the overflow when it contracts as it cools down. The "overflow" tank is really a common expansion tank.
Old Mar 7, 2006 | 01:02 PM
myxbuddy's Avatar
JDazzle
overflow tank
alright thanks for the help
Old Mar 7, 2006 | 03:40 PM
RX7 allnight's Avatar
707
i am having/had the same problem we will see havent been able to drive it long enough to tell check my tread as it may help it just got back up today
https://www.rx7club.com/showthread.p...=1#post5383461
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
James Knox
Oct 5, 2015 07:56 AM
