Factory Radio
Old Feb 6, 2002 | 12:53 PM
Angel Guard Racing Team's Avatar
Factory Radio
OK I found out where the cables go and hooked everything up. My radio still does not work! The lights turn on with the dashboard, the antenna goes up and no display, no castte deck no eq or sound. Then I pulled it out again and outside the car I hooked it up to a 12V+ and NO ground. The casette deck worked, the display lighted up but no radio station numbers just an orange screen, the program and dolby buttons worked in other words everything worked except the dark display numbers. I checked the fuses inside the car (kick panel) and no fuses are blown. Could it be that I am getting no power from the accessories (ignition) switch cable?.
I don't need diagrams, I know the cable colors and where they belog and the ground on the radio is very good. So if you reply to this just keep in mind that I have used the SEARCH button and have not found what I am looking for.
Old Feb 6, 2002 | 04:33 PM
Jodoolin's Avatar
Had the same problem (I think) you described. However, had sound. The LCD were blank orange. If I ran finger over them it was fluid under neath. Radio was an original 90 GTU with Clarion radio. Kaput! Clarion LCD replacements no longer available.
Old Feb 6, 2002 | 05:22 PM
Icemark's Avatar
two reasons that the display doesn't work...
One: missing 12v+ constant into the radio. there needs to be switched and constant.
Two: bad radio.
pretty simple...
Old Feb 6, 2002 | 05:42 PM
Icemark's Avatar
heres the plug layout BTW:
Old Feb 6, 2002 | 09:32 PM
Thanks
Old Feb 6, 2002 | 09:39 PM
CosmicButtHairs's Avatar
Save the TII from a V8
Hey IceMark, may I ask you where you got that picture and if theres anymore you have or I can find on the web??
Old Feb 6, 2002 | 11:09 PM
Icemark's Avatar
Actually I scanned it in this afternoon from the factory shop manual and posted it
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
