Need bulb info for bulbs that go behind the temp controls
Old Mar 5, 2006 | 02:31 PM
Tim Benton's Avatar
FD title holder since 94
This is probably up Dale's alley, so hopefully he can help me. One of my small lights went out that goes behind the temp control dials. There's 4 that go in there so I was going to replace all 4 to just get it over with. Took the bulbs out and on the bulb it says S:14V 1.4w. The closest I could find at the parts store was 1.2w of the same size. Anyone know what the part number is for these tiny bulbs and where I can get them. I tried the manual but really couldn't pin point a bulb number for them. And for that matter, what bulb replaces the one that had gone out for the lighted keyhole entry?
Tim
Old Mar 5, 2006 | 03:43 PM
FDNena's Avatar
I
This is the list of bulb numbers I have from the Sylvania site. The only one it gives is for the instrument panel but maybe it is the same?
1993 MAZDA RX-7
High & low beam headlamp
9003
9003ST Silverstar High Performance Lighting: the whitest and brightest Halogen
9003XV XtraVision Halogen Upgrade: Up to 30% Brighter
9003CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
168
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
3497
Rear turn signal
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
1157
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Lighting: the whitest and brightest Halogen
License plate
168
194
Back up light
1156
1157
Cornering
1157
Front sidemarker
168
Rear sidemarker
194
Glove box
194
Map light
168
Dome light
168
194
Trunk/Cargo area
DE3175
Instrument-general
194
Old Mar 5, 2006 | 05:12 PM
Tim Benton's Avatar
Thanks for the reply. I used that site as well, but it's not one of those. The one that came close was a sylvania 3721 or maybe a 2721 bulb. After plugging in the 1.2 w compared to the 1.4w, I doubt I'll notice a difference. I'll wait a couple more days and wait before I put the dash back in since it's a pain to take out just to swap out the little bulbs. I had gotten new interior dash pieces (94 model for my 93) to get rid of the scratch prone pieces. Just wanted to do it all while I was in there.
What about the lock light? Looks like it's directly wired to the bulb.
Tim
Old Mar 5, 2006 | 08:53 PM
BOTTLEFED's Avatar
Freudian slip
The bulbs you probably found were #74 bulbs. That is all that is commonly available to replace them; like you said, you won't see a difference.
The key-light is the same, you will just have to pull hard (but carefully) on the bulb to get it out of the socket - it is very tight
-Tim
Old Mar 5, 2006 | 09:13 PM
CantGoStraight's Avatar
What's your point ?
I got mine from radio shack. Don't remember the part number (or where I wrote it down) but you should be able to find it in there store.
Old Mar 5, 2006 | 09:34 PM
Tim Benton's Avatar
About the key light, I should clarify. I was referring to the light that is right above the door lock, not the ignition light. The one for the door lock seemed to be wired in, ie not a plug type. I appreciate the help with the bulbs, I'll just use the 1.2w bulbs if I can't track a few down at the local Radio Shack tomorrow. I guess I could bend the light wires out and solder them to the wires for the door lock and see if that works.
I also bought a new door lock set since mine had the usual plastic slider (the piece that pushed inward when you inseted the key) busted and looked like crap.
Tim
Old Mar 6, 2006 | 02:54 PM
BOTTLEFED's Avatar
Freudian slip
Oh, sorry, I misunderstood.
For the light in the door lock, it is wired in and needs to be soldered in. I actually replaced it with a LED - it might even be easier.
Old Mar 6, 2006 | 07:19 PM
What's your point ?
Do you have any part numbers diagrams for the led installation ? ? ?
fastsaab
Aug 19, 2015 11:42 AM
