high rev problems possible answers?
Old Mar 5, 2006 | 11:09 AM
RX7Junkman's Avatar
Unhappy high rev problems possible answers?
many of u may have know by now i'm going to do a 5spd conversion and add a single turbo but i'm still waitin for some of the part to come in but in the mean time I turn on the car once in a while so it doesnt just sit in the driveway but the past 2 times ive started it, it revs at 1500 (doesnt rev down) then the engine just shakes violently. may it already be time for a rebuild, please share your knowledge?
Old Mar 5, 2006 | 11:11 AM
RX7Junkman's Avatar
also white smoke from the exhaust, and it only happens in park.
Old Mar 5, 2006 | 06:02 PM
RX7Junkman's Avatar
bump
Old Mar 6, 2006 | 09:35 AM
RX7Junkman's Avatar
another bump
Old Mar 6, 2006 | 09:44 AM
Mahjik's Avatar
Mr. Links
What is on the car currently? Is is all or pretty stock "as is" when you are starting it?
Old Mar 6, 2006 | 12:04 PM
RX7Junkman's Avatar
the only thing on it is that ive put on a 3" full cat-back exhuast and a pettit intake other than that stock
Old Mar 6, 2006 | 12:10 PM
Mahjik's Avatar
Mr. Links
Did it start doing this after those were installed or did it just start out of the blue?
I would first check and see if you have all your connectors seated properly (i.e. things like the TPS and the MAP/BOOST sensor).
Old Mar 6, 2006 | 12:42 PM
RX7Junkman's Avatar
out of the blue, at first I thought it was the map sensor but its not i checked all the lines to see if there are any loose but cant find anything wrong
Old Mar 7, 2006 | 06:25 AM
RX7Junkman's Avatar
bump
Old Mar 7, 2006 | 07:43 AM
Mahjik's Avatar
Mr. Links
Try driving it around for a bit. See if it just needs to burn off some oil. It could be several things but you are going to have to get your hands dirty and start checking a few things.
Check your fluid levels, see if anything is lower than normal. To the quck Coolant Bubbles test, etc.
Old Mar 7, 2006 | 09:16 AM
RX7Junkman's Avatar
not familer with the coolant bubble test, please explain
Old Mar 7, 2006 | 11:08 AM
RX7Junkman's Avatar
so it may not necessarilly be the engine thats the problem?
Old Mar 7, 2006 | 05:49 PM
RX7Junkman's Avatar
now its black smoke not white, maybe too rich
wickedrx2
The Bad & Fugly Members
Jun 10, 2021 06:28 PM
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
13
Jan 9, 2018 11:19 AM
