The tricky parts of the intake manifold!
Old Feb 6, 2002 | 07:54 AM
Samps's Avatar
After doing a good bit of work on my intake system, I've decided to state some points of the intake that are a pain in the ***.
Tough stuff:
1- getting the 5th and 6th port sleeves to stay on the lil actuator arms sticking out of the lower manifold, while you push it up against the block. And trying to believe that they actually stayed on.
2- getting that lil spacer back in that goes between the air pump brackets. (I almost gave up)
3- should have been number one but; getting all of the cooked on gaskets off. And not letting any of the gasket poop get into the motor.
4- getting all of the hoses back on after the temperature drops to 10 degrees, and the hoses get hard like rocks.
5- screwing the oil injectors back in. They were kinda hard to get out too.
6- finding the parts you dropped inside a garage with a gravel floor (a lot of time wasted here)
did I mention getting the gaskets off!!!
Old Feb 6, 2002 | 07:58 AM
OPEC's Avatar
Re: The tricky parts of the intake manifold!
Yeah scrapping gaskets sucks.. I have done it many times. I imagine it must really suck in the freezing cold.
Old Feb 6, 2002 | 09:42 AM
HAILERS's Avatar
HAILERS
Spacer on the airpump??? Don't take the air pump off that way anymore. There are three bolts that hold the bracket to the engine. Take those three bolts out and the adjusting bolt in the lower bracket. The spacer will stay with the airpump and bracket.
Old Feb 6, 2002 | 10:32 AM
Samps's Avatar
Didn't realize that . I have the mazdatrix strut brace and it has a triangle plate that must bolt onto those same bolts, but it also covers up the assembly behind it. So I really couldn't tell that the bracket could be removed . Well next time, you better believe I will do it that way. That spacer seemed to grow to almost twice its size when I tried to put it back in.
Old Feb 6, 2002 | 01:59 PM
SpeedRacer's Avatar
Formula Mazda Driver
Tough stuff:
hehe...I know what you mean man...I've had problems with each of those issues before, except for the garage with a gravel floor bit.
Old Feb 6, 2002 | 02:03 PM
Felix Wankel's Avatar
Super Newbie
Stuff paper towels in the ports before you start scraping. Lucky for me I have an air compressor and a pneumatic gasket remover tool
Old Feb 6, 2002 | 02:09 PM
Samps's Avatar
How does a pneumatic gasket remover work?
Old Feb 6, 2002 | 02:20 PM
Super Newbie
Fancy name for an air grinder with a special rubber wheel
Old Feb 6, 2002 | 04:27 PM
ka8legend's Avatar
Tough stuff:
3- And not letting any of the gasket poop get into the motor.
Next time, you can insert the actuator arms in AFTER slapping on the lower mani. They only go in a certain way so they's no mistake unless the sleeves were put in wrong to begin with.
I used gasketcinch with good result, easy to apply, and easy to come off when you need to de-install; highly recommended by major racing teams.
Old Feb 7, 2002 | 07:45 AM
Samps's Avatar
Re: Re: The tricky parts of the intake manifold!
I was talking about the arms that stick out of the other side of the manifold that actually attach to the sleeves. They have a groove that has to wrap around the lil pins on the sleeves. This needs to be done before you bolt up the manifold. I wish it was that easy.
C. Ludwig
Jan 30, 2019 06:31 AM
Engine stand ready
Aug 14, 2015 10:26 PM
