I live in a world with no emissions...
Old Mar 2, 2006 | 04:12 PM
I live in Michigan, where there is no annual smog or emissions testing. My question is: what unnecessary systems can be tossed on my FD? Smog pump? Vaccuum lines, etc.? I'm already planning an a full cat delete, but I was wondering if I could simplify the rat's nest more.
Old Mar 2, 2006 | 04:14 PM
OneRotor's Avatar
RAWR
IBTL
read the FAQ's at the top. You can get rid of the air pump, and there is, i believe, a simplified vacuum diagram.
Old Mar 2, 2006 | 04:54 PM
dgeesaman's Avatar
Port your wastegate before doing the full cat delete.
Off the top of my head, you can eliminate:
- TB Coolant supply
- AWS
- Air Pump / ACV
- Double Throttle
- Cruise control
Check out the 'simplified sequential' diagram and note which solenoids are removed and what things they would have run to. Then check out www.fd3s.net or run some forum searches to get more info on each.
Dave
Old Mar 2, 2006 | 05:32 PM
audiobot7's Avatar
Ahh du ma! El Es Juan!
lucky you, Cali sucks.
Old Mar 2, 2006 | 06:59 PM
jpandes's Avatar
Thanks Bee
Old Mar 2, 2006 | 07:04 PM
rotoober's Avatar
one part from Nirvana
Yea thanks for rubbing in your no-smog problem! I'm taking mine in again tomorrow @ 2:30: i'm glad you don't have to go thru the worry we do every two years...
Old Mar 2, 2006 | 07:50 PM
xxxtodxxx's Avatar
hey where i live in ohio there isn't any smog checks. hope that never changes
Coochas
44
Nov 5, 2019 11:08 PM
Sethix
Nov 3, 2017 11:48 PM
frosty1993
Sep 30, 2015 01:27 PM
