Power FC Smoothed Base Map - COMMENTS PLEASE!
Old Mar 2, 2006 | 02:04 AM
4CN Air's Avatar
DETH TRP
Got the datalogit working, I threw the data into Excel to smooth it a little. It's nice cause you can just move the points on the lines directly and Excel modifies the table for you. Makes smoothing very easy.
I'd like some input on my values though since this is my first bit of tuning.
It didn't seem to fix my surging/bucking that I experience under 3000rpms though. Light throttle driving is still a bit of a chore. It seems liek i fix it, then it just comes back. It seems to get worse with warmer weather, but then it got colder tonight and it didn't get any better. I'm really lost, I'm thinking it's ignition rather than fuel related at this point.
I'll be changing my plugs and checking out my ignition maps tomorrow.
Thanks for any help provided.
Attached Thumbnails Smoothed Base Map - COMMENTS PLEASE!-grid.jpg   Smoothed Base Map - COMMENTS PLEASE!-map.jpg
Old Mar 4, 2006 | 01:19 AM
Aeka GSR's Avatar
i dont have an answer to your question, but what excel program are you using to smothe data?
Old Mar 4, 2006 | 01:31 AM
4CN Air's Avatar
DETH TRP
just graph the data, then you can click directly on individual data points and move them up or down, this will change the corresponding cell automatically. Then when you're doen just copy and paste it back into FC Edit and "write all"
Old Mar 4, 2006 | 04:21 PM
Aeka GSR's Avatar
never thought about that, awesome.
Old Mar 4, 2006 | 09:14 PM
mark57's Avatar
Temple of Cornd0g
What WBO2 do you use?
Old Mar 5, 2006 | 08:42 PM
4CN Air's Avatar
DETH TRP
those aren't AFR's just injection settings. I need to get a WB02, of course I need to get my own datalogit too, lol.
Old Mar 6, 2006 | 08:26 AM
mark57's Avatar
Temple of Cornd0g
I presumed you had a Datalogit, WBO2 and that you know better than to manipulate the Base Map with unconfirmed bogus values that "look pretty". "Pretty timing" may finish off your engine.
Old Mar 6, 2006 | 02:49 PM
4CN Air's Avatar
DETH TRP
OUCH!
I had it tuned by Dave @ KDR, so it was a safe tune, but we didn't get any time on the street. A couple values in the vacuum/low RPM range would go the wrong way and things like that, I just smoothed them out a little, which is recommended in the tuning articles/threads I've read. This was not done for LOOKS!
Also I was adding fuel to try and fix the surging/hesitation issue at low RPM/light throttle. The only thing I'd have to worry about destroying is spark plugs. Thanks for the bump though.
Old Mar 7, 2006 | 07:31 AM
twokrx7's Avatar
Need more sleep
It's near impossible to look at your base fuel table and make an assessment. Smoothing is a good deal after some afr tuning if you want to get everything as linear as possible, meaning you want your personal "ideal" values of afr across and up the map with minimal variation from cell to cell or run to run or when dropping or upping boost. The downer of this is that you need to recheck your afr as it will change after you make adjustments to the base map. I'm not sure it will do much for you in the low load non-idle areas and I doubt that Dave touched them. If you have some driveability issues at light load get some kind of afr meter on it and adjust the afr accordingly, you may have to mess with the accel enrichment if it's going lean on throttle tip-in.
Idle can be a different story. I discovered that making all the cells around my idle point have the same or near same fuel and timing really locked down my idle (along with a lot of other map changes and underhood deletions of course). Not sure if you would call this smoothing but it works well.
Old Mar 7, 2006 | 10:50 AM
4CN Air's Avatar
DETH TRP
I was just trying to rule out the possibility of there being some glaring problem in my maps that I just couldn't see. Accel maps were enriched a little, and my idle is good.
I'll post more useful maps once I hook up a WBO2.
Old Mar 7, 2006 | 04:22 PM
DaleClark's Avatar
RX-7 Bad Ass
I've been playing with the acceleration enrichment values lately, and have smoothed out a lot of low RPM bucking. Most times it's an accel pump issue, not necessarily the map. If you have jerkiness when you suddenly give it throttle, time for the accel map.
Neat trick with Excel, though!
Dale
Old Mar 8, 2006 | 12:24 AM
4CN Air's Avatar
DETH TRP
Question with the accel map. Say you want more fuel right at tip in, you increase the left column. The right column is decay but this doesn't necessarily require an increase if the corresponding left column gets an increase does it?
Old Mar 8, 2006 | 12:28 AM
4CN Air's Avatar
DETH TRP
An Innovative LC-1 is all I would need right? Good deal on them here: http://cgi.ebay.com/ebaymotors/Innov...QQcmdZViewItem
seems liek what I'd be looking for since I don't need a gauge and the controller is nicely built into the lines. Any problems with this setup on a datalogit? Accurate setup?
Old Mar 8, 2006 | 12:39 AM
RX7_Fanatic's Avatar
R.I.P. DAVE
anyone know if steve kan will tune to fix low rpm bucking and such nonsense that we all encounter with our FD's? From what i've read he does, but i wanted to know if anyone has some before/after experiences...
and keep us updated on how your smoothing goes, my damn car acts like a bucking bronco if its pissed at certain temps and such...pisses me off
edit: idle sux too most of the time
Old Mar 8, 2006 | 12:44 AM
4CN Air's Avatar
DETH TRP
Yeah Steve does primarily street tuning from what I've seen. Then if you want to add dyno tuning he'll do that too. I've heard people raving about the driveability increase and often increase in MPG after his tuning sessions.
Old Mar 8, 2006 | 01:43 PM
mark57's Avatar
Temple of Cornd0g
Actually, you do need the gauge - so buy the LM-1 or the XD-1. Do you own a Commander?
Old Mar 8, 2006 | 05:19 PM
4CN Air's Avatar
DETH TRP
I wouldn't need the gauge with a datalogit though, right? I'm borrowing one now but will be purchasing one soon.
Old Mar 9, 2006 | 04:00 PM
fritts's Avatar
Mad Man
You don't need a gauge as you can use the 0-5 volt out on the LC-1 to input into the datalogit. I am using the LC-1 with the datalogit currently. After seeing the way the datalogit records the AFR in the map, I think that a guage should only be used to look for gross AFR problems.
Old Mar 12, 2006 | 08:32 PM
4CN Air's Avatar
DETH TRP
UPDATE: discovered the surging problem!
(my spark plug end at L1 connection beside a good one)
Attached Thumbnails Smoothed Base Map - COMMENTS PLEASE!-fdfdfdffdfdfdfdf.jpg
24seven_dada
20
Nov 10, 2018 12:03 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
befarrer
Sep 4, 2015 08:26 PM
