replaced lower intake manifold now smoke is comming from the turbos???
Old Mar 1, 2006 | 03:50 PM
viper_u27's Avatar
hi everyone
im having somewhat of a problem here
as the thread states, i replaced my lim gasket and now after putting it all back together, im getting smoke from around the turbos. its not a sweet smell and its not blue so i think its neither antifreeze or oil. it also is not a fuel smell...any ideas?
im running my turbos non-seq, and i have injectors and fuel rail, microtech, in case one of these guys has something to do with it.
Old Mar 1, 2006 | 05:06 PM
ALNY93R1's Avatar
I would double check the oil and coolant feed and return lines.
Old Mar 1, 2006 | 05:09 PM
DaleClark's Avatar
RX-7 Bad Ass
Whenever you pull the turbos, you always get greasy hands, oil, coolant, etc. all over stuff. It will all burn off, making smoke and stankyness.
If it persists, you may have a leak somewhere. But, some smoking first time you fire up the car is totally normal.
Dale
Old Mar 2, 2006 | 12:26 PM
viper_u27's Avatar
Thanks guys....
i think it was the pb blaster that i used to loosen up the bolts a bit, heating up and smoking. smoke is gone now after about ten minutes or so
Engine stand ready
Aug 14, 2015 10:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
