Sponsored by: CARiD
NOn-oxygenated Fuel
Old Feb 5, 2002 | 09:10 PM
Enthu's Avatar
Still has an RX7.
NOn-oxygenated Fuel
I am wondering if any one knows if there is an advantage/risk to using non-oxygenated fuel. one of the stations around here offers 92 octane non-ox. would I risk causing damage to the engine if I used it?
Old Feb 6, 2002 | 01:12 AM
peejay's Avatar
Old [Sch|F]ool
Wow you can find non-oxygenated fuel? I can't find any that isn't 10% alcohol or whatever.
Oxygenated fuel basically has MTBE or other chemicals added to it so that there's oxygen in the fuel. It's a very poorly concieved emissions reduction scheme - in theory emissions are caused by running too rich, so by adding oxygen to the fuel the cars will run leaner. (Do you really want this in a turbo rotary??? I assume you have a turbo 'cos you're looking at 92 octane) In actuality the vast vast majority of cars on the road have feedback EFI so all oxygenated fuel does is make MPG worse because the computer compensates for it.
Old Feb 6, 2002 | 03:30 PM
Enthu's Avatar
Still has an RX7.
I have an FD with a recently rebuilt engine, so I take it running the non-ox woudl be better? it says there "for small engines, SUVs, classic cars"..etc. at the gas station. So I'll start using it then.
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
